Software Archive
Read-only legacy content
17060 Discussions
skip cilk-plus in gcc testsuite?
TimP
Given that gcc cilk-plus isn't supported on Windows Subsystem for Linux, and plans have been advertised for its removal from gcc 8, is there a way to avoid running the failing cilk-plus tests in gcc testsuite?  Configuring --disable-libcilkrts stops the attempt to build libcilkrts but doesn't skip the failing tests.  I hadn't yet removed all copies of libcilkrts.so .a and .spec from the WSL installation
