Software Archive
Read-only legacy content
17061 Discussions
sony tz27 at 1920x1200 dell 2408
mailspambin
I have a sony tz27 but when i plug it into the dell 2408 24in monitor it only displays up to 1600x1200
is it possible to have it at 1920x1200?
Intel_C_Intel
Difficult to figure out which drivers you have... I think the TZ27 is the GMA 950... Can you go into the Intel Graphics Tray, click on the Information button, and then click Save to Disk and post the saved file here?
mailspambin
Intel Graphics Media Accelerator Driver for Mobile Report
Report Date: 09/16/2008
Report Time[hr:mm:ss]: 22:03:47
Driver Version: 7.14.10.1387
Operating System: Windows Vista Business* , (6.0.6000)
Default Language: English
DirectX* Version: 10.0
Physical Memory: 2037 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 256 MB
Graphics Memory in Use: 106 MB
Processor: x86 family 6 Model 15 Stepping 2
Processor Speed: 1197 MHZ
Vendor ID: 8086
Device ID: 27A2
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel 945 Express Chipset Family
Video BIOS: 1358
Current Graphics Mode: 1600 by 1200 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
Non Active Notebook Displays: 1
* Monitor *
Monitor Name: Dell 2408WFP(Analog)
Display Type: Analog
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 20.0 inches
Vertical: 12.0 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (60 Hz)
800 by 600 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (75 Hz)
1152 by 864 (75 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
1600 by 1200 (60 Hz)
1920 by 1200 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 ff ff ff ff ff ff 00 10 ac 29 a0 53 33 43 31
1a 12 01 03 0e 34 20 78 ea b3 25 ac 51 30 b4 26
10 50 54 a5 4b 00 81 80 a9 40 71 4f 01 01 01 01
01 01 01 01 01 01 28 3c 80 a0 70 b0 23 40 30 20
36 00 07 44 21 00 00 1a 00 00 00 ff 00 47 32 39
31 48 38 36 51 31 43 33 53 0a 00 00 00 fc 00 44
45 4c 4c 20 32 34 30 38 57 46 50 0a 00 00 00 fd
00 38 4c 1e 53 11 00 0a 20 20 20 20 20 20 00 8d
* Notebook *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 3.54
Maximum Image Size: Horizontal: Not Available
Vertical: Not Available
1366 by 768 (40 Hz)
1366 by 768 (60 Hz)
Display Power Managem ent Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
* Other names and brands are the property of their respective owners.
mailspambin
i tried to install the latest driver from intel website, but when i run the file it said something like it is not approved by the vendor or something along that liune :(
Intel_C_Intel
Thanks. That helps. Sony likely has their own special,"approved and validated by Sony"configuration of the Intel drivers, and therefore the latest Intel ones won't load on your machine.
It's okay. It looks like you have something relatively recent.
I'd grab DTDCalc and go to the "Reverse Calculation" tab. Insert
28 3C 80 A0 70 B0 23 40 30 20 36 00 07 44 21 00 00 1A
into the frame there, hit "Reverse Calculate", and then proceed to the "Registry Hack" tab and Get Calculatednext to one of the DTD entries (if there are none, click "More" to create one) and Write DTDs toRegistry.
Reboot and you should have 1920x1200 as a selectable resolution. If not, it's possible Sony has specifically disabled 1920x1200 in the BIOS. Get around this by using
28 3C 7E A2 70 B0 23 40 32 20 36 00 07 44 21 00 00 1A
which is 1918x1200 and shouldn't be disabled.
mailspambin
Nice!
its working at 1918x1200 now.
looks like sony did disable 1920x1200 on purpose
will it affect the laptop or the monitor by using 1918x1200?
Intel_C_Intel
As long as you don't mind not seeing two pixels on each line, there should be no other effects.
mailspambin
Oh i m sure my eyes cant tell the difference!
thanks for the help.
sonyquestion
I'm having a similar problem. I have a Sony VGN-TX670P, with an Intel 915GM, and I'm trying to export 1920x1200 to a Dell 2408. The link earlier in the thread to DCDCalc isn't working for me. Can you help? Here's the report:
Report Date: 01/31/2009
Report Time[hr:mm:ss]: 11:10:44
Driver Version: 6.14.10.4333
Operating System: Windows XP* Professional, Service Pack 3 (5.1.2600)
DirectX* Version: 9.0
Physical Memory: 1014 MB
Maximum Graphics Memory: 128 MB
Graphics Memory in Use: 18 MB
Processor: x86 family 6 Model 13 Stepping 8
Processor Speed: 598 MHZ
Vendor ID: 8086
Device ID: 2592
Device Revision: 03
Accelerator in Use: Mobile Intel 915GM/GMS,910GML Express Chipset Family
Video BIOS: 1220
Current Graphics Mode: 1366 by 768 True Color (60 Hz)
Active Monitors: 1
* Monitor *
Monitor Name: Plug and Play Monitor
Gamma Value: 2.20
Maximum Image Size: Horizontal: 20.4 inches
Vertical: 12.5 inches
640 by 480 (60 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (60 Hz)
800 by 600 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (75 Hz)
1152 by 864 (75 Hz)
* Notebook *
Monitor Name:
Gamma Value: 3.54
640 by 480 (60 Hz)
1024 by 768 (60 Hz)
1366 by 768 (60 Hz)
Thanks in advance for your help!
Aaron_B_Intel
Those drivers are too old to work with DTDCalc-- the ability to add a custom resolution didn't show up until 14.25.50.4764-- which is, I believe, the final XP driver for 915G, in any case.
If you can upgrade to that set of drivers you can then apply the DTDCalc fix to your PC to get a custom resolution.
(I fixed the DTDCalc link... it had been stripped of the site address, for some reason).
sonyquestion
sonyquestion
Quoting - sonyquestion
Aaron,
Thanks for the speedy reply. I'm glad to hear the problem is the driver, not the hardware. Do you know where I can download the driver I need? I tried to download updates off the Intel site, but I don't think I'm where I need to be. Here is the info, after my last update (It looks like the driver version changed):
Report Date: 02/02/2009
Report Time[hr:mm:ss]: 08:52:02
Driver Version: 6.14.10.4764
Processor Speed: 1198 MHZ
Vendor ID: 8086
Device ID: 2592
Device Revision: 03
Video BIOS: 1220
Active Monitors: 1
* Monitor *
Gamma Value: 2.20
640 by 480 (60 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (60 Hz)
800 by 600 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (75 Hz)
1152 by 864 (75 Hz)
* Notebook *
Monitor Name:
Gamma Value: 3.54
1366 by 768 (60 Hz)
Thanks, again, for your help. Sony support was a big waste of time, and I'm in over my head in figure this one out on my own.
Aaron_B_Intel
You're on 4764, which should work with DTDCalc. Whatbehavior have you seen so far?
sonyquestion
After seeing your email that 4764 should work with DTDCalc, I downloaded it and tried to run it. However, I got the following error: "To run this application, you first must install one of the following versions of the .NET Framework: v2.0.50727. Contact your application publisher for instructions about obtaining the appropriate version of the .NET Framework." What now?
Thanks, again, for your help,
Vic
sonyquestion
Excellent! DTDCalc is running now. Should I also use 28 3C 7E A2 70 B0 23 40 32 20 36 00 07 44 21 00 00 1A
with DTDCalc or do I need use something else since I don't have precisely the same computer as the guy you were helping earlier in the post?
Aaron_B_Intel
DTD settings are monitor-dependent, not driver or chipset, so that one should be fine for the Dell monitor you guys have been discussing.
