Software Archive
Read-only legacy content
sshfs
Geert_G_
Hello all,
Our cluster has a number of nodes with each 2 mics. One of the things I can't seem to get working is access to our scratch space wich makes use of gpfs. I was thinking sshfs would be the most simple and straight forward solution for this problem. I googled around a bit, and apparently busybox supports sshfs. Can anyone confirm busyboxs ability to support sshfs? Does anyone know why busybox for the mics is not compiled with support for sshfs? Is there any good documentation on how to re-compile os binaries for the mic?
Thanks!!
Best regards, Geert
JJK
New Contributor III
I just downloaded busybox 1.24 (oct 2015) and cannot find any support for sshfs ... building sshfs itself is possible, but also requires builds of glib-2.0 and gthread-2.0
