Software Archive
Read-only legacy content
17060 Discussions
sssd instead of ldap
Jan_N_
Hi all, I would like to ask if there is a way to use sssd i stead of ldap for user authentication to mic? Thank you very much Jan
JJK
New Contributor III
as far as I can tell the sssd code has not been ported to the Phi (yet), so the short answer is no.
The long answer is: sure, if you're willing to port sssd and all client stuff to the Phi
Jan_N_
What does it mean? Recompile all needed source rpms? Is there any nice howto or documentation or so? (could not find anything that could help me)
JJK
New Contributor III
Yes , you'd need to recompile it from source, including all dependencies. And especially with a package like sssd the list of dependencies is lengthy, so you're in for a log, slow and painful process. At first glance I saw that sssd requires
  • popt
  • talloc
  • glib2
and quite a few more, most of which are not available for the Xeon Phi (so you'd need to rebuild those as well)
I have not found any guides on building RPMs for the Xeon Phi, but I'd expect it to be very similar to building RPMs for other OSes (such as Redhat EL 6/7 or CentOS 6/7) , as the Xeon Phi setup is very similar to a RHEL distro.
