Software Archive
Read-only legacy content
17061 Discussions
status clause don't work
Alexander_Komarov
Hi there,
I try to use status clause, but I even can't compile example from http://software.intel.com/en-us/articles/effective-use-of-the-intel-compilers-offload-features by name "NEW in Intel(R) Composer XE 2013 SP1: Example of Error Condition Checking with status ". I get message
tbo_sort.c(142): error: identifier "_Offload_status" is undefined
_Offload_status x;
tbo_sort.c(147): error: argument to the "status" clause must be a variable of type "_Offload_status"
#pragma offload target(mic) status(x) in(p[0:elements])
tbo_sort.c(155): error: identifier "OFFLOAD_SUCCESS" is undefined
if (x.result == OFFLOAD_SUCCESS) {
tbo_sort.c(159): error: identifier "OFFLOAD_OUT_OF_MEMORY" is undefined
if (x.result == OFFLOAD_OUT_OF_MEMORY) {
I used Intel Composer 13.3.163. Is this ability supported?
Kevin_D_Intel
The support is not present in the 13.x compiler (from the Composer XE 2013 release) that you used. It appears in the Composer XE 2013 SP1 release (w/14.x compiler) only now in Beta test and due to release later this year.
