Hi, there.
I wanted to run mic_samples that I was sure that Xeon Phi work.
I compiled, but when I am running program, I get message that "target unavailable" and "Offload sections will execute on: Host CPU (fallback mode)".
Samples started
Checking for Intel(R) MIC Architecture (Target CPU) devices...
Number of Target devices installed: 0
PASS Sample01
PASS Sample02
PASS Sample03
PASS Sample04
PASS Sample05
PASS Sample06
*** FAIL Sample07 - target unavailable
PASS Sample08
PASS Sample09
PASS Sample10
PASS Sample11
*** FAIL Sample12 - target unavailable
*** FAIL Sample13 - target unavailable
*** FAIL Sample14 - target unavailable
Samples complete
Is it mean that Xeon Phi don't work?
May be, I didn't install all of program for Xeon Phi.
Alexander
It's samples from folder "./mic_samples/intro_sampleC".
Also, I try to run samples from folder "./mic_samples/Leo_tutorial/". But I get message
C/C++ Tutorial: Offload Demonstration
offload error: cannot offload to MIC - device is not available
The samples are indicating the Xeon Phi card is not available. Did you verify that the card is booted? Try running the /opt/intel/mic/bin/micinfo command to see if the card is booted.
I run micinfo:
MicInfo Utility Log
Created Fri May 24 16:17:12 2013
System Info
HOST OS : Linux
OS Version : 3.1.0-1.2-desktop
Driver Version : 5889-16
MPSS Version : 2.1.5889-16
Host Physical Memory : 16434 MB
Device No: 0, Device Name: mic0
Version
Flash Version : 2.1.01.0385
SMC Boot Loader Version : 1.8.4326
uOS Version : 2.6.38.8-g9b2c036
Device Serial Number : ADKC25001680
Board
Vendor ID : 8086
Device ID : 2250
Subsystem ID : 2500
Coprocessor Stepping ID : 3
PCIe Width : x16
PCIe Speed : 5 GT/s
PCIe Max payload size : 256 bytes
PCIe Max read req size : 512 bytes
Coprocessor Model : 0x01
Coprocessor Model Ext : 0x00
Coprocessor Type : 0x00
Coprocessor Family : 0x0b
Coprocessor Family Ext : 0x00
Coprocessor Stepping : B1
Board SKU : B1PRQ-5110P/5120D
ECC Mode : Enabled
SMC HW Revision : Product 225W Passive CS
Cores
Total No of Active Cores : 60
Voltage : 983000 uV
Frequency : 1052631 KHz
Thermal
Fan Speed Control : N/A
SMC Firmware Version : 1.13.4570
FSC Strap : 14 MHz
Fan RPM : N/A
Fan PWM : N/A
Die Temp : 35 C
GDDR
GDDR Vendor : Elpida
GDDR Version : 0x1
GDDR Density : 2048 Mb
GDDR Size : 7936 MB
GDDR Technology : GDDR5
GDDR Speed : 5.000000 GT/s
GDDR Frequency : 2500000 KHz
GDDR Voltage : 1000000 uV
Interesting. Card appears functional.
What version of Composer do you have installed? (icc -V)
Can you set the environment variable OFFLOAD_REPORT=3, re-run either sample and then post only about the first twenty lines of output into a reply
Have your source’d the compilervars.sh/.csh script accordingly?
It seems others suffered a similar error as you when not doing so. http://software.intel.com/en-us/forums/topic/391415
Here's probably the problem. If you happen to manually modify your environment after sourcing the compilervars.sh/.csh and the LD_LIBRARY_PATH does not include /opt/intel/mic/coi/host-linux-release/lib then you will suffer the error you have.
I have installed version of ICC:
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.1.117 Build 20121010.
Thank you for reference on other post. I watched their.
I ran compilersvars.sh. But, It is same error.
I entered on the card and checked if coi_daemon is running. And I got the following log:
4888 root 0:00 grep coi
Coi_daemon is not running. What do I do to run coi_daemon?
The error response you showed in your original post is not what I see when attempting to run the samples with the coi daemon not running. In the absence of the coi daemon the sample hangs after displaying Checking for Intel(R) Xeon Phi(TM) (Target CPU) devices.. and eventually fails with offload error: cannot get device 0 handle (error code 1).
Double check your environment setting for LD_LIBRARY_PATH to ensure the path to /opt/intel/mic/coi/host-linux-release/lib is present in the setting and that the path exists on your system and that similar files (dates/sizes may vary depending on the installed MPSS version) as shown below reside under this location:
[bash]# ls -l /opt/intel/mic/coi/host-linux-release/lib
total 1184
-rwxr-xr-x 1 root root 601641 Dec 17 05:02 libcoi_host.so
-rwxr-xr-x 1 root root 601641 Dec 17 05:02 libcoi_host.so.0[/bash]
To reboot the card and attempt to restart the coi daemon, as root on the host execute: micctrl -R
micctrl --help will display additional help on all available options.
My problem is fixed. My problem was that when I run compilervars.sh, environment setting don't set. Necessary run this script from file ".profile"(". /opt/intel/composerxe/bin/compilervars.sh intel64"). Default, installer wrote to file ".profile". But I don't have this line in my ".profile", because I deleted this line.
I wrote this line and everything was working.
Thank you so much.
Glad to hear everything is working. I'm not sure what installer you are referring to. Ours does not modify the .profile.
Yes, I was wrong, I modified manually this file. But when run compilersvars.sh from ".profile", not necessary every time manually to run compilersvar.sh. So it is convenient.
