Software Archive
Read-only legacy content
17060 Discussions
text integer conversion
Intel_C_Intel
This is a newbie question, have the following code, which works acceptably but am wondering if there is a simpler way to do it? I want to have a list box with a selection of integers or real numbers available as choices. I want to read the operators selection, do some calculations with this choice and then output them back to a different dialog box. If there is a way I would store the originals in the intput box as integers or reals, rather than strings. As it is I read a string, convert it to and integer, do the calculations, convert back to an string and then send it back to the other dialog box.
I'm sure this is trivial, let me know if there is a more straight forward way.
Jim
  logical retlog
! read input from dialog box
    retlog = DlgGet( dlg, idc_input, index )
!  convert string to integer
    read(index,*) value
!  perform calculations
    value3=value*3
!  convert integer value back to string
    write(index2,'(I4)') value3
!  send output as string back to different dialog box
    retlog = DlgSet( dlg, IDC_OUTPUT, index2 )
Jugoslav_Dujic
Valued Contributor II
That's the only sure way. There are Win32 APIs GetDlgItemInt and SetDlgItemInt (use Dlg%hWnd as the first argument) but I'm not sure whether they'd work correctly in conjunction with DFLOGM (I foresee problems with updating of edit box contents).
I usually use a home-brew helper library for working with strings. That will avoid necessity for having a character dummy variable for writing (but not for reading),
something along these lines:
MODULE STRINGS
INTERFACE STRING
   MODULE PROCEDURE FSTRING
   MODULE PROCEDURE ISTRING
END INTERFACE
CONTAINS
FUNCTION FSTRING(fValue, iWid, iPrec) RESULT(s)
!Writes fValue into string of length iWid with iPrec decimals
CHARACTER(LEN=iWid):: s
REAL, INTENT(IN):: fValue
INTEGER, INTENT(IN):: iWid, iPrec
CHARACTER(10):: sFormat
INTEGER:: iErr
WRITE(sFormat, "('f', i3.3,'.', i3.3)") iWid, iPrec
WRITE(s, sFormat, IOSTAT=iErr) fValue
END FUNCTION FSTRING
!ISTRING is for your excercise :-)
END MODULE STRINGS
So, your last line would look like retlog = DlgSet( dlg, IDC_OUTPUT, STRING(index2, 4) )
HTH
Jugoslav
