Software Archive
Read-only legacy content
17060 Discussions
unable to build MPSS RPM in CENTOS 7 VM
Surya_Narayanan_N_
I am unable to build MPSS 3.6 either from source nor from the already built RPM with my kerbel version which is supposed to be compatible for mpss 3.6
[root@localhost src]# uname -a
Linux localhost.localdomain 3.10.0-229.el7.x86_64 #1 SMP Fri Mar 6 11:36:42 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
when i try to build source using "rpmbuild --rebuild mpss-modules*.src.rpm" I get the following error captured in mpss2.PNG
when i try to build the rpms using "yum intall *.rpm" i get the errot captured in mpss_1.PNG breaking with some dependencies.
Frances_R_Intel
I'm a little confused. Were you trying to install from the src directory for some reason? You should not need to rebuild the MPSS with the kernel version you have. I would suggest that you back up, remove any partial install and go through the steps in section 2.2 of the README file that comes with MPSS 3.6. If you want to try rebuilding the mpss module after that, you should be able to do so.
