Software Archive
Read-only legacy content
unable to ssh to mic1
VIKRANT_G_
hello
i am have a system with two mic cards and i am trying ssh into them from xeon host,
i can do ssh mic0 and access mic0 and run native application,
but i cannot access mic1 via ssh,
when i do ssh mic1 the screen just hangs,
when i do miccheck it shows both mic0 and mic1 online  and also micinfo gives proper info for both the cards
I also started the MPSS service on both cards and cleared firewall
thank you for the help in advance
Loc_N_Intel
Hi Vikrant,
Your mic1 wasn't flashed properly for some reasons, you may want to flash both coprocessors again. See Section 7.2 of the readme file:
% sudo micctrl -rw
% sudo /opt/intel/mic/bin/micflash -update -device all
Restart your system. Then update SMC boot-loader after login on the host:
% sudo micctrl -rw
% sudo /opt/intel/mic/bin/micflash -update -smcbootloader -device all
Restart your system again.
VIKRANT_G_
any suggestions for this issue, i also read the MPSS guide but could not find the solution for the issue
thank you
TaylorIoTKidd
I'll take a look at your issue.
Taylor
TaylorIoTKidd
Please post the micinfo results.
Taylor
VIKRANT_G_
here is the result from micinfo:-
System Info
                HOST OS                 : Linux
                OS Version              : 2.6.32-279.el6.x86_64
                Driver Version          : 6720-19
                MPSS Version            : 2.1.6720-19
                Host Physical Memory    : 32827 MB
Device No: 0, Device Name: mic0
        Version
                Flash Version            : 2.1.01.0385
                SMC Firmware Version     : 1.13.4570
                SMC Boot Loader Version  : 1.4.3581
                uOS Version              : 2.6.38.8-gefd324e
                Device Serial Number     : ADKC23700157
        Board
                Vendor ID                : 0x8086
                Device ID                : 0x225c
                Subsystem ID             : 0x2500
                Coprocessor Stepping ID  : 3
                PCIe Width               : x16
                PCIe Speed               : 5 GT/s
                PCIe Max payload size    : 256 bytes
                PCIe Max read req size   : 4096 bytes
                Coprocessor Model        : 0x01
                Coprocessor Model Ext    : 0x00
                Coprocessor Type         : 0x00
                Coprocessor Family       : 0x0b
                Coprocessor Family Ext   : 0x00
                Coprocessor Stepping     : B1
                Board SKU                : B1QS-7110 P/A
                ECC Mode                 : Enabled
                SMC HW Revision          : Product 300W Active CS
        Cores
                Total No of Active Cores : 61
                Voltage                  : 1087000 uV
                Frequency                : 1100000 kHz
        Thermal
                Fan Speed Control        : On
                Fan RPM                  : 2400
                Fan PWM                  : 50
                Die Temp                 : 48 C
        GDDR
                GDDR Vendor              : Elpida
                GDDR Version             : 0x1
                GDDR Density             : 2048 Mb
                GDDR Size                : 7936 MB
                GDDR Technology          : GDDR5
                GDDR Speed               : 5.500000 GT/s
                GDDR Frequency           : 2750000 kHz
                GDDR Voltage             : 1501000 uV
Device No: 1, Device Name: mic1
        Version
                Flash Version            : NotAvailable
                SMC Firmware Version     : NotAvailable
                SMC Boot Loader Version  : NotAvailable
                uOS Version              : NotAvailable
                Device Serial Number     : NotAvailable
        Board
                Vendor ID                : 0x8086
                Device ID                : 0x225c
                PCIe Width               : x16
                PCIe Speed               : 5 GT/s
                Board SKU                : NotAvailable
                ECC Mode                 : NotAvailable
                SMC HW Revision          : NotAvailable
        Cores
                Voltage                  : 0 uV
        Thermal
                Fan Speed Control        : NotAvailable
                Fan RPM                  : NotAvailable
                Fan PWM                  : NotAvailable
                Die Temp                 : NotAvailable
        GDDR
                GDDR Version             : 0x1
                GDDR Size                : 7936 MB
                GDDR Voltage             : 0 uV
Loc_N_Intel
Hi Vikrant,
% sudo micctrl -rw
% sudo micctrl -rw
VIKRANT_G_
thanks loc-nguyen'
that re-flashing worked, i am now able to do ssh mic1
thanks taylor, i did post the micinfo results but i think the reply is queued for approval
