Software Archive
Read-only legacy content
17060 Discussions
understand realsense capabilities
Massimiliano_B_2
Hello everybody,
I want to make a 3D body scan with high precision and I'm looking for what could be the best solution.
Realsense seems to be the cheapest tool but I didn't find some information that I need.
If someone could answer me I'd really appreciate :)
1) There is a Labview API for Realsense? If not someone has tried to integrate realsense into labview projects in other ways?
2) Is possible to refer the 3d scan to a frame on the Realsense? Something that lets me to determine the position of the body into the room (distance from the sensor and orientation) and match images from two cameras.
3) what is the precision of realsense? I mean the greatest accuracy and precision error in millimiters into a range of 0.1 m^3 at a distance of 50 cm for example.
Thankyou in advance
Xusheng_L_Intel
1, RealSense SDK did not have LabView API
2, No, maybe you can try SP MW for this requirement.
3, It depends the object size you scanned.
