Hello All.
I Have html5 website. I wanted to this Web site to make an android application. I have a laptop with Windows 10. Intel hdk installed on my computer.
Import documents and made application. I uploaded it on Google Play.
After my time came following email:
"The vulnerabilities in some versions of Apache Cordova include a high severity cross-application scripting (XAS) vulnerability. Under certain circumstances, susceptible apps could be remotely exploited to steal sensitive information, such as user login credentials.
For guidance on upgrading Apache Cordova, please see:
http://cordova.apache.org/
To confirm you’ve upgraded correctly, submit the updated version of your app to the Developer Console and check back after five hours to make sure the warning is gone."
So, By looking only have the opportunity 5.1.1 and 4.1.2
Can anyone help me with this problem? How can I fix? I really need a solution to this problem. Please help me. Step by step I explain what to do. thanks
Thank You!
Richi
- Tags:
- HTML5
- Intel® XDK
Hello Richi,
Which version of CLI and Crosswalk did you use to build your app? You should only be getting this message if you used CLI 4.1.2 and built with Crosswalk 7. Any other combination should not result in this issue. Please provide that information.
Paul
