Software Archive
Read-only legacy content
17060 Discussions
using cilkview and cilkscreen
newport_j
Where is their some instruction or document on using cilkview and cilkscreen? I do believe that what is in the Programmer's Guide is current/correct. It seems that cilkview at least has a lot of different functionality.
Where can learn about hw to use cilkview and cilkscreen as they exist today?
Thanks in advance.
newport_j
Georg_Z_Intel
the latest documentation is contained in Intel Cilk Plus Software Development Kit. After extracting there will be a sub-directory called "doc" which contains one HTML file.
There's an out-dated knowledge base article, too:
http://software.intel.com/en-us/articles/visualizing-parallel-speedup-with-cilkview/
I'm currently about to revise it.
Georg Zitzlsberger
newport_j
I know that some hahve chaged since that outdated document, but to will still hacve to use
cv.start
cv.stop
and
cv.dump
I just need to know what must be in the c source code to use cilkview reliably. It seems the old methods (without the cilk object) are okay.
Any help appreciated.
Newport_j
Georg_Z_Intel
didn't my answer on this thread help you:
http://software.intel.com/en-us/forums/showthread.php?t=102901
? (reply #2)
It's exactly the same approach.
cv.start/stop/dump are not used anymore. Instead, use:
[bash] cilkview_data_t start; __cilkview_query(start); // profile this here __cilkview_report(&start, NULL, "my_tag", CV_REPORT_WRITE_TO_RESULTS); [/bash]
Georg Zitzlsberger
newport_j
It is having trouble finding my cilkview.h file. It is in
../Desktop/cilkutil/include/cilktools/
which is not in my $PATH. How can I correct this?
1. I can makean additonal $PATH section to it (it is getting to be a long $PATH).
2. I can move cilkview.h, cilkscreen.h and any other header file in that cilkutil directory to another include file directory tha is in my $PATH.
I do not know which one is best or even if there is another way.
What can I/ should I do?
Any help appreciated. Thanks in advance.
Newport_j
Georg_Z_Intel
use "-I" like this
$ icpc -I/Desktop/cilkutil/include/cilktools/
...to help the compiler find the include directory for the cilktools' header files (here: cilkview.h).
You don't need to set $PATH; just use "-I" as described above.
Georg Zitzlsberger
