Software Archive
Read-only legacy content
17060 Discussions
what are the Windows App Equivalent permisions in xdk windows settings...?
Leonidas_S_
Android Permissions:
ACCESS_FINE_LOCATION;ACCESS_MOCK_LOCATION;ACCESS_NETWORK_STATE;INTERNET;ACCESS_COARSE_LOCATION;LOCATION_HARDWARE;ACCESS_LOCATION_EXTRA_COMMANDS;READ_CONTACTS;WRITE_CONTACTS;GET_ACCOUNTS;WRITE_EXTERNAL_STORAGE
what are the Windows App Equivalent permissions in xdk windows 8/10 app settings...?
Swati_S_Intel1
ID_CAP_MAP
Not needed in windows app if using google maps... true?
Only the permission     ID_CAP_LOCATION
needed true...?
That's correct.
use comma or semicolon like android semicolon????
Both are fine.
Swati_S_Intel1
Windows apps use Capabilities for example ID_CAP_CONTACTS for contacts, ID_CAP_LOCATION for location etc.  You can specify capabilities in the permissions field in Intel XDK. You can find list of Capabilities here : https://msdn.microsoft.com/en-us/library/windows/apps/jj206936(v=vs.105).aspx
Leonidas_S_
ID_CAP_CONTACTS;ID_CAP_LOCATION;ID_CAP_MAP;ID_CAP_MEDIALIB_PHOTO;
really the:
ID_CAP_MAP
needed for Google Maps(also Show My Location button) not windows Maps????
Also what separator must be between Windows App permissions.. like Android...";"...?
Swati_S_Intel1
You can use comma to separate the CAP entries. I'm not sure if I understand your other question. ID_CAP_MAP is used for accessing Windows Maps and you have to use Windows Map API to display the map. For using Google Maps use Geolocation plugin (part of Core Plugins under Plugins Management in the Projects tab of XDK) and Google Maps API. I hope this helps.
Leonidas_S_
So the permission
ID_CAP_MAP
needed true...?
Swati_S_Intel1
ID_CAP_MAP
needed true...?
That's correct.
Both are fine.
