Software Archive
Read-only legacy content
17060 Discussions
xdk issue when not building for crosswalk
Roi_D_
There is an issue in the xdk (build 3759) when I want to build apk without crosswalk.
My project has "Optimize with Crosswalk" checkout but in the build tab I have a note that some values have errors and not to fix it in the project details.
It took me some time and the issue is with crosswalk. I needed to check "Optimize with Crosswalk" and below choose crosswalk version 19 (was marked 18 with a note that there is a security risk). Now I can uncheck "Optimize with Crosswalk" and the build tab doesn't report any error.
So the build tab is checking the crosswalk version even though "Optimize with Crosswalk" is checked out.
Roi
PaulF_IntelCorp
Roi -- thanks for that heads up. The orange (!) symbol simply indicates a warning (although, in the scenario you describe it is a false warning). When the orange (!) symbol is present it does not prevent you from performing a build, but it can be confusing. I will file a bug regarding this confusing point.
Roi_D_
Note that it's not just false positive of the warning indicator. XDK actually doesn't let me execute the build process until I fix the version even though crosswalk is checked out. so I needed to check crosswalk, change version, uncheck crosswalk just so XDK will let me execute the build process.
PaulF_IntelCorp
Odd, in my experiment I was able to leave the Crosswalk version (!) warning icon on the Build Settings page, uncheck the optimize, and still do a build. I did my build with CLI 6.2.0, not sure if that makes any difference for you. I only attempted an Android build.
Roi_D_
you are right. I checked again. what I was doing before is probably just going over with the mouse and seeing the msg that I have an issue and need to fix it. but I can do the build.
so it's just a display issue as you said.
thanks
