Software Archive
Read-only legacy content
17061 Discussions
[yocto linux]: [ERROR] S is not set to the linux source directory
Ravindranath_D_
When building yoctolinux for galileo i encounter below build error. How to fix this?
ERROR: Function failed: do_kernel_checkout (log file is located at /home/swathi/internet_of_things/iotdk_src_140220/meta-intel-iot-devkit/build/tmp/work/clanton-poky-linux/linux-yocto-clanton/3.8-r0/temp/log.do_kernel_checkout.23829)
ERROR: Logfile of failure stored in: /home/swathi/internet_of_things/iotdk_src_140220/meta-intel-iot-devkit/build/tmp/work/clanton-poky-linux/linux-yocto-clanton/3.8-r0/temp/log.do_kernel_checkout.23829
Log data follows:
| DEBUG: Executing shell function do_kernel_checkout
| [ERROR]: S is not set to the linux source directory. Check
|          the recipe and set S to the proper extracted subdirectory
| WARNING: exit code 1 from a shell command.
ERROR: Task 343 (/home/swathi/internet_of_things/iotdk_src_140220/meta-intel-iot-devkit/meta-clanton-bsp/recipes-kernel/linux/linux-yocto-clanton_3.8.bb, do_kernel_checkout) failed with exit code '1'
Ravindranath
Brendan_L_Intel
Can you paste the log.do_kernel_checkout.23829 on a pastebin website or similar?
Also please tell us what distribution you are using and what arch you are running on (you must be on 64bit for sstate to work)
Ravindranath_D_
Hi Brendan,
Thanks for your response. Please find the log file details below:
ERROR: Function failed: do_kernel_checkout (log file is located at /home/swathi/internet_of_things/iotdk_src_140220/meta-intel-iot-devkit/build/tmp/work/clanton-poky-linux/linux-yocto-clanton/3.8-r0/temp/log.do_kernel_checkout.1445)
My machine details:
I am working on a 32-bit Ubuntu 12.04 LTS
steps I followed till now:
Basically I have problems with my network in accessing the link "git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git;branch=linux-3.8.y" which is referred in "meta-clanton-bsp/recipes-kernel/linux/linux-yocto-clanton_3.8.bb". I am getting a time-out error when trying to access the link and the build is failing. So, I have modified the link to " http: // git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git;branch=linux-3.8.y". Also added the below details for the build to progress:
SRC_URI[md5sum] = "06cd35eea3eb91c3a8e287721dd15294"
SRC_URI[sha256sum] = "433ce6b669b99842311e4f196feee4d227654b5e1f7b0aac06606918fdb864df"
From what I suspect, the linux sources are not populated in the "iotdk_src_140220/meta-intel-iot-devkit/build/tmp/work/clanton-poky-linux/linux-yocto-clanton/3.8-r0/linux" path. So, the script is not able to checkout the sources and hence the error.
I have tried downloading the linux source code tarball "linux-yocto-clanton-3.8-r0-.tar.gz" and placing the kernel code in the respective directory. But I am facing some issues with respect to "validate_branch" function. Help me out in:
1. Building the source with tarball and
2.Is there any way I can successfully populate the sources without resorting to tarball? Because, going forward, I will be adding further components to the linux kernel and would require the git sturcture to contribute back.
Eugenio_W_Intel
was this resolved, running into the same issue
