Hello pbalt1,
In order to change the RAID 10 to RAID 5 it's necessary to delete the RAID 10 array and then reconfigure the available Disks to RAID 5 from scratch then with the valid backup you can restore your data.
Adrian M.
Hello pbalt1,
I was looking into your case, we recommend to check with the system manufacturer of your system/Hard drives as well because they could have guidance in order to rebuild the RAID since you have to recreate it, make sure you have a back up of all your information as previously mentioned.
Adrian M.
