I have three RAID1 configurations on an ASRock E3C222D4U motherboard running Intel RST Enterprise 4.3.0.1542.
I'm replacing it with a different motherboard, an ASRock E3C246D4U. Not 100% sure, but most likely also has Intel RST Enterprise chipset.
My question is, can I just setup the BIOS to RAID, then move the C: pair of drives to SATA 0/1, then the
Am I correct to assume the RAID config is stored on the drives themselves?
In theory, yes, you should be able to move the drives over and have it work (yes, the information is stored on the drive, though I do not know the logistics). In practice, I have seen this work, but not for generational upgrades. I suggest you move your system array and see if it goes ok -- but only after you make a full backup.
