Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
351 Discussions
RSTe not removed Error 0x80070643
MPota1
Hi . Server 2008 r2 . RTSe 5.2.2.1022 not removed .
Error 0x80070643
is it possible to delete manualy ?
Hello, Mihail_Potapov;
Thanks for contacting Intel® Rapid Storage Technology enterprise (Intel® RSTe) support; in regards to your issue we would like to recommend you trying to run the installer as if you were to re-install the software again and from the installer select the option that says "Uninstall"; if there's no Uninstall option you can try to "Re-install" the software again and try to uninstall it in the conventional way, that should help you with your issue; please let us know if that helps addressing your problem.
Also, please remember that if you require more assistance or want to add additional details, we'll be glad to assist you
Chris.
Hello, Mihail_Potapov,
Thanks for your time and we're replying to your thread as a follow-up to your case and to see if the information that we've provided you was useful for your situation.
Please remember that if you require more assistance or want to add additional details, we'll be glad to assist you.
Chris.
Thanks for your time and we're sending you this message as a follow-up to your case and to see if the information that we've provided you was useful for your situation.
At this point we'll close your case; however, if you want to re-open your case and require more assistance or want to add additional details, we'll be glad to assist you.
Chris
