Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
VROC NVMe SMART
Cla777
Is there a way to collect SMART information for NVMe that has RAID configured with VROC?
I would like to know when to replace the NVMe drive.
Thank you.
BHarr8
Valued Contributor I
Piggybacking on this question because it is related. Is there a tool that can update Optane drive firmware when configured in VROC?
I was surprised to see that I can indeed update 800P firmware when in Optane acceleration mode through Intel's firmware tool, but it can't see into my VROC array.
JosafathB_Intel
Hello Cla777,
Thank you for contacting Intel® Memory and Storage support.
As we understand, you need assistance with your Intel® Virtual RAID on CPU (Intel® VROC). If we inferred correctly, please review and provide us with the following information:
1- We advise you to contact your Motherboard OEM (original equipment manufacturer) to get further assistance regarding your Intel® VROC configuration and compatible SSD.
Please consider that the OEM creates and modifies their solutions to fit their needs, and they have their list of compatible hardware and software that sometimes is different from our list. For example, there are cases that some of the systems need a specific BIOS or software configuration to be able to work with an OS, add-on hardware, or feature.
2- Provide us with the logs from our RAID solutions like RST/RSTe/VROC follow the System Reports for Intel® Rapid Storage Technology article:
https://www.intel.com/content/www/us/en/support/articles/000006351/technologies.html
3- We would appreciate it if you can provide us with the system details by extracting the SSU logs and the replication steps.
The SSU logs.
• Go to https://downloadcenter.intel.com/download/25293/ (for Windows*) and to https://downloadcenter.intel.com/download/26735/ (for Linux) download the software.
• When you finish downloading it, open it.
• Attach the file generated by the tool in your reply.
4- To answer your questions:
it depends a lot on the OEM compatibility and if the drives are connected or not directly to the board. If you have Intel® SSD's you need to use the:
 Intel® Memory and Storage Tool (GUI)
https://downloadcenter.intel.com/download/30161/Intel-Memory-and-Storage-Tool-GUI-
Or the:
Intel® Memory and Storage Tool CLI (Command-Line Interface) https://downloadcenter.intel.com/download/30162?v=t
To check the SSD life remaining or to update your SSD firmware if they are recognized as shown in the following screenshots:
- If you have third-party SSDs on your VROC configuration, please contact the SSD manufacturer to check if their tool is compatible with VROC.
-To answer BHarr8 question:
The Intel® Optane™ SSD 800P Series is not a supported SSD, and we do not recommend using it with VROC.
Based on the Intel® Virtual RAID on CPU (Intel® VROC) Supported Configurations article:
https://www.intel.com/content/www/us/en/support/articles/000030310/memory-and-storage/ssd-software.html
The supporter NVMe SSDs are the following:
We will follow up with you again the next Friday, the 26th of February 2021, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
We will be looking forward to your reply in case you need further assistance.
Josh B.
Intel® Customer Support Technician.
JosafathB_Intel
Hello Cla777,
Greetings from; Intel® Memory and Storage support.
We were reviewing your community thread, which is related to your Intel® Virtual RAID on CPU (Intel® VROC). We would like to know if you were able to check our previous post.
We will follow up with you again the next Tuesday, the 2nd of March 2021, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
Josh B.
JosafathB_Intel
Hello Cla777,
Since we have not heard from you in a while, we are going to close this community thread.
If you need further assistance related to an Intel® product, please do not hesitate to contact us back by opening a new thread.
Jos B.
