Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
351 Discussions
WHEA Logger Event ID: 17 Warning Flood - Component: PCI Express Root Port
nolto
I am getting multiple Event 17 “Corrected hardware error” PER SECOND. I’ve logged more than 12 thousand at this point.
The device is Intel PEG60 - 9A0F
fNvuW7r
A corrected hardware error has occurred.
Error Source: Advanced Error Reporting (PCI Express)
Primary Bus:Device:Function: 0x0:0x6:0x0
Secondary Bus:Device:Function: 0x0:0x0:0x0
Primary Device Name:PCI\VEN_8086&DEV_9A0F&SUBSYS_50151558&REV_05
Secondary Device Name:
The connected device is Crucial P2 500GB PCIe M.2 2280 SSD "CT500P2SSD8"
Windows and all of the drivers are updated
Device name	EMRE-Clevo
Processor	11th Gen Intel(R) Core(TM) i5-11400H @ 2.70GHz   2.69 GHz
Installed RAM	16.0 GB (15.8 GB usable)
Device ID	553629F7-03D0-4E04-8406-86CBFD550ADA
Product ID	00331-10000-00001-AA614
System type	64-bit operating system, x64-based processor
Pen and touch	No pen or touch input is available for this display
Edition	Windows 10 Pro
Version	22H2
Installed on	‎23/‎05/‎2022
OS build	19045.2486
Experience	Windows Feature Experience Pack 120.2212.4190.0
I change the power management settings to "high" and there is no power-saving policy on any device currently. Battery saver disabled in bios.
There are dozens of titles on this subject on the internet and none of the ones I've read have been a solution for me.
n_scott_pearson
Have you considered that it might be the Crucial SSD? If you remove/replace this drive, does the same issue occur?
Just a thought,
