Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
hyper m.2 raid 0 on x299 chipset
craig5
Trying to add a raid 0 set-up to my asus prime x299-deluxe. I have the card installed and can see the 4 m.2 drives in the bios but the vroc set-up shows all the drives as unsupported. Can access the drives in Windows no problem (Samsung 980 4tb). Is there a fix for this issue other than the vroc key, which at $400 seems like a bad choice, given I could go to a new amd board and CPU for the same price taking me to pcie 4 allowing the hyper m.2 to run at the full 128 Gbps. Given the age of this x299 chipset you would think there would be a patch to fix this, without needing a key
Azeem_Intel
Hello craig5,
Greeting for the day!
I hope you’re doing well. Could you please confirm whether the product was shipped with the system or purchased separately?
Azeem
craig5
Yes the card was supplied with the board, and the manual shows how to configure the bios to make it work. The manual does state only raid 0 is supported without the key, which is OK as that is what I want so I can load/SAVE my CAD files quickly, which often are about 50Gb files
ManoranjanDas
Hello craig5,
Greetings for the day!
Based on your inquiry, RAID 0 can be configured and used without a key, whereas RAID 5 requires a key for proper support and functionality. If you have any further questions or need additional assistance with RAID configurations or any other technical issues, please do not hesitate to reach out. We are here to assist you.
Thank you for using Intel products and services.
Manoranjan.
craig5
OK so how do I get the bios to allow the drives to be used in raid zero when it's shows all of them as VMD0 (unsupported). Currently running version 4001 bios. Do I need a specific bios version or can you send me a patch to fix this.
ManoranjanDas
Hello craig5,
Since you are using an ASUS system, we recommend contacting ASUS directly for the BIOS file, as our support does not cover BIOS issues on Original Equipment Manufacturer (OEM) devices.
Manoranjan.
craig5
OK so you are passing the problem on to asus, even though Intel coded the lock out on VROC and the x299 chipset. Given the huge problems Intel have at the moment with the 13 and 14th gen CPU failures due to chip corroding inside, I would think the least Intel could do is supply a VROC key free of charge to try and get some good publicity instead of all the bad publicity Intel has been getting for the last few months. email me privately if you want to discuss this further
ManoranjanDas
Hello craig5,
Thank you for your response.
Our official statement related to VROC configurations using the X299 chipset is the following:
Intel® VROC is targeted as an enterprise product, mainly for Servers and Workstations. Also, per the details found in the article “Intel® VROC Support on X299 FAQ”, Intel® VROC was enabled on X299 client platforms (see below). This initial decision was made at the time of launch in 2017. Since then, it has become apparent that Intel® RST (and not Intel® VROC) is the better product to support SSD RAID on X299 platforms, partly because of Intel® RST availability, broad SSD support and no need for an extra HW key. Intel® RST is free and it supports Intel® as well as NON-Intel® storage devices.
Intel® VROC will continue to have its HW Key licensing policies, which are more in line with enterprise product expectations. From the above explanation, we hope it’s clear that for X299 / client platforms, our customers do NOT require purchasing Intel® VROC key for RAID 0 (even with NON-Intel® drives). Please use Intel® RST instead of Intel® VROC for RAID 0 and other things.
For more detail, please review the full FAQ; especially answer to question 2 in the below article:
https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/ssd-software/VROC_Support_on_X299_FAQ.pdf
Please take into consideration that there may be differences in features and configuration even between boards of the same manufacturer and they may require specific hardware and BIOS configuration, this being said we advise you to contact your OEM (original equipment manufacturer) for further information regarding BIOS and hardware configuration to use these solutions.
I hope you find this information helpful.
Manoranjan.
Azeem_Intel
Hello craig5,
I checked the User Manual for your system (ASUS Prime X299-Deluxe), and it indeed states that VROC RAID 0 is supported without a key. However, it also mentions that due to CPU behavior, CPU RAID functions with Intel VROC only support Intel SSD devices. These "Intel SSD devices" refer to the formerly Intel NAND SSDs, now Solidigm SSDs, which we no longer support. There were specific formerly Intel SSD models that allowed setting up RAID 0 without a VROC key in the past. This is no longer available. To properly use VROC in an X299 system, you should use the hardware key.
Even if you had the hardware key, according to the User Manual, only formerly Intel SSDs are supported. That means your current drives (Samsung SSDs) will not be compatible. This is likely why the drives are showing as unsupported.
Azeem
Azeem_Intel
Hello craig5,
I hope you're doing well. This is our first follow-up. Please let us know if you have any additional queries. If not, can we proceed to close the case?
Azeem
Azeem_Intel
Hello craig5,
This is the second follow-up regarding the reported issue. We're eager to ensure a swift resolution and would appreciate any updates or additional information you can provide.
Azeem
Azeem_Intel
Hello craig5,
This is the third follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Azeem
