Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
ssd caching with Raid5
oGaut
I got a raid 5 on a C236 Chipset, i also got on the same motherboard an M2 SSD. I run a Windows Server 2016.
I can't find a version of RSTE with ssd caching. And RST (not e) version i found didn't want to install on my server.
Is there a solution to that problem?
Thank you
Hello
Thank you for contacting us.
In order to better assist you, please tell us:
Your system specifications:
OS
Motherboard
RAM
CPU
Storage devices
Please also let us knowr which SSDs are you planning to use.
Once we get this info we will proceed with the next best actions
Kind regards
oGaut
OS : Windows 2016 server
Motherboard : ASUS P10S WS S1151 C236
RAM : 16 Go ECC (2* KVR24E17S8)
CPU : CORE I7-7700K 4.20GHZ
Storage devices :
- Raid 5 (3*DBSLA0020H 2TB)
- 2 * 4TB (WD40EZRZ)
- 1 * SSD intel 5400S M2 48 G (SSDSCKKR048) This is the one i want to use as cache
Thank you
Thank you for the prompt response, we will be looking forward on the information to gather a correct answer by the Intel Rapid Storage Technology Team
Hello got_fr
In regards to your question
Intel® RSTe supports the ability to enable/disable write back cache through the Intel® RSTe GUI. write back Cache is disabled by default.
Please keep in mind that enabling write back cache will improve the RAID logical drive performance but may cause unwritten cached data loss if power is lost.
You can enable the write back cache feature under advanced tab on the raid configuration
Pleases check page 61 of the Intel® RSTe User Guide https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/g40440_005_rste_swug_r1_5.pdf here
If this is not the feature that you are looking for you can also take advantage of the Intel® Smart Response Technology that comes with Intel® RST, you can find more information https://www.intel.com/content/www/us/en/architecture-and-technology/smart-response-technology.html here
Best Regards
Luis H
Hello got_fr,
We are following on your post status since we provided you with advise on your question, however we haven't received a reply yet.
Please let us know if you require further assistance
Best Regards
Luis H
oGaut
Hello
Write back cache isn t what i want. I want to use an m2 ssd as cache.
Rst isn t an option my system didn't accept it.
Thank you
Hello got_fr,
We would like to inform you that Intel® RSTe doesn't have a feature to setup an SSD as cache device.
In your case our best recommendation will be to take advantage of the Intel® Cache Acceleration Software which is a software that Intel has developed in order to use SSD's as cache devices. You can check more information about the software https://www.intel.com/content/www/us/en/software/intel-cache-acceleration-software-performance.html here
Luis H
Hello got_fr,
Thanks for your time and we're sending you this message as a follow-up to your question and to see if the information that we've provided you was useful for your situation.
Please remember that if you require more assistance or want to add additional details, we'll be glad to assist you
Chris
