1840 Discussions
Access to Processor Counter Monitor has denied with pcm-memory.x
lai_z_
          I built and ran the pcm-memory.x tool on CentOS 7 with Intel Xeon E3-1230 V5,but display as follows:
[root@localhost pcm-master]# ./pcm-memory.x
 Processor Counter Monitor: Memory Bandwidth Monitoring Utility  (2018-07-17 12:46:01 +0200 ID=e9b093b)
 This utility measures memory bandwidth per channel or per DIMM rank in real-time
Number of physical cores: 4
Number of logical cores: 8
Number of online logical cores: 8
Threads (logical cores) per physical core: 2
Num sockets: 1
Physical cores per socket: 4
Core PMU (perfmon) version: 4
Number of core PMU generic (programmable) counters: 4
Width of generic (programmable) counters: 48 bits
Number of core PMU fixed counters: 3
Width of fixed counters: 48 bits
Nominal core frequency: 3400000000 Hz
Package thermal spec power: 80 Watt; Package minimum power: 0 Watt; Package maximum power: 0 Watt;
Access to Processor Counter Monitor has denied (no MSR or PCI CFG space access).
Cleaning up
     Whether the pcm-memory.x tool not support the skylake CPU or I need to change some parameters?
Roman_D_Intel
does pcm.x work for you?
could you please share strace output?
strace -f -o pcm-memory.strace.out ./pcm-memory.x
lai_z_
Hi,Roman,
     I can run the pcm.x tool when I disabled the NMI_watchdog,and I typed 'strace -f -o pcm-memory.strace.out ./pcm-memory.x' at the command
line,the output is the same as running ./pcm-memory.x command.The output is as follows:
[root@localhost pcm-master]# strace -f -o pcm-memory.strace.out ./pcm-memory.x
Num sockets: 1
Cleaning up
Roman_D_Intel
could you please attach the pcm-memory.strace.out file produced by strace?
lai_z_
Hi,Roman,
    The attach file is a file generated by strace.
Roman_D_Intel
thanks! Could you please also send me the content of /proc/cpuinfo file?
lai_z_
Hi,Roman,
    The attachment is the cpuinfo file.
Roman_D_Intel
thank you. Unfortunately your processor does not have the hardware PMU unit that pcm-memory requires. pcm.x supports memory traffic metric as a replacement. PCM-memory will be updated to print this information.
Roman
lai_z_
Hi,Roman,
    Thanks for your reply,can you tell me which models of E3 series CPU have the hardware PMU unit?
Roman_D_Intel
As far as I know only E5 and E7 series from that CPU generation have this unit
lai_z_
Hi,Roman,
    I found the release notes for version 2.10 of the PCM tool on this page: https://software.intel.com/en-us/articles/intel-performance-counter-monitor/ ,details are as follows:
  • Support Memory Bandwidth Monitoring technology (new local and remote memory bandwidth reported per (logical) core in pcm.x/exe)
  • Added support of Broadwell-based Intel®Xeon®E3 series
  • Added support of processor models based on archtitecture code-named Skylake U/Y.
  • New option for pcm (-yescores to enable specific core output)
  • Bug fixes
    How to monitor memory bandwidth with the pcm.x/exe? What are the features that support Broadwell-based Intel®Xeon®E3 series?Whether Haswell and Ivy Bridge E3 series can be supported?
Roman_D_Intel
in pcm.x/exe you can find metrics called "READ" and "WRITE":
 READ  : bytes read from main memory controller (in GBytes)
 WRITE : bytes written to main memory controller (in GBytes)
sample output:
MEM (GB)->|  READ |  WRITE |   IO   | CPU energy |
 SKT   0     5.07     0.41     1.10      13.38
