Software Tuning, Performance Optimization & Platform Monitoring
Discussion regarding monitoring and software tuning methodologies, Performance Monitoring Unit (PMU) of Intel microprocessors, and platform updating.
Can't run the Intel Power Gadget
John_D_8
초급자
10,807 조회수
I'm trying to run the Intel Power Gadget on a Win 8.1 x64 system with a Core i7-720QM.  The program and the MS Visual C++ 2010 redistributable library appear to install OK, but the tool will not start.  I try launching it, and nothing happens.  I attached windbg to the executable, but did not learn anything.  I also investigated it with Process Monitor and Dependency Walker, but couldn't get to the bottom of it.
The same utility runs fine on a different computer.  Curiously, I might have not installed the MSVC 2012 redistributable on that PC.  I don't see it listed in Programs and Features.  The power gadget runs just fine though.
Any ideas?
0 포인트
1 솔루션
Seung-Woo_K_Intel
10,807 조회수
I should put up a dialog box when it's not supported rather than quietly quitting. Another idea for the next release... :)
원본 게시물의 솔루션 보기
0 포인트
11 응답
Bernard
소중한 기여자 I
10,807 조회수
Can you post screenshot of Dependency Walker and screenshot of windbg output? In your case Power Gadget can exhibit so called Silent Process Termination.
0 포인트
John_D_8
초급자
10,807 조회수
Attached are 4 files.  Two are screenshots from Dependency Walker and windbg, and two are text outputs from those utilities.
Thanks for thinking about it.
0 포인트
Seung-Woo_K_Intel
10,807 조회수
I am the author of Intel Power Gadget. Can you tell me your machine's spec? Please run CPUZ utility and send me the report.
0 포인트
John_D_8
초급자
10,807 조회수
I also posted this on StackOverflow.  A user kindly analyzed the executable and came up with this conclusion:
i took a look at the offending exe it seems there is an integer division by zero exception in EnergyLib64.dll->Initialization Routine called by initterm (LdrpRunInitializeRoutine) when it checks for some processor specific functionality using cpuid the result of cpuid after some calculations is shifted right by 20 shr eax,20 which makes eax 0 and the divisor ebp is also 0 so div eax, ebp results in a divide by zero exception which leads to immediate termination. via msvcrt!exit at 0x......9e78
So, it seems that there's a bug which only affects systems with certain CPUs.
Can someone at Intel report this to the utility authors?  The authors appear to be: Seung-Woo Kim, Karthik Krishnan, Vardhan Dugar, Joseph Jin-Sung, and Jun De Vega.
0 포인트
Seung-Woo_K_Intel
10,807 조회수
We are still using VS 2010 for backward compatibility, so the run time distributable that comes with the package should be enough. There must be something else going on.
0 포인트
John_D_8
초급자
10,807 조회수
Attached is a screenshot from CPUZ.  Thanks for investigating.
0 포인트
Seung-Woo_K_Intel
10,807 조회수
That's why I asked for CPU-Z report to get the exact CPU specification, which comes from cpuid :)
0 포인트
John_D_8
초급자
10,807 조회수
Attached is the full CPU-Z report as a text file in case you need more info than the screenshot I posted earlier.
0 포인트
Seung-Woo_K_Intel
10,807 조회수
Yep, it's Clarksfield. Intel Power Gadget supports SandyBridge and later.
0 포인트
Seung-Woo_K_Intel
10,808 조회수
0 포인트
John_D_8
초급자
10,807 조회수
OK, thanks.  I read the System Requirements too quickly and thought that all Core CPUs were supported.
0 포인트
응답
