Code Coverage Generation
David_B_24
I have a large live Fortran solution which I periodically build with Code Coverage switched on by setting /Qcov-gen in a special copy of ifort.cfg file used for the purpose.
I want to disable some of the projects from the Code Coverage statistics and so I tried the documented option /Qcov-gen- in the Fortran project command line properties. Unfortunately this generated the following message for each source file:
ifort: command line warning #10006: ignoring unknown option '/Qcov-gen-'
How can I disable individual projects in my solution from being included in the Code Coverage report?
Patrick_F_Intel1
Hello David,
If you post your code to the compiler forums, you'll probably get better, quicker responses.
Maybe try Intel® Visual Fortran Compiler for Windows*  or Intel® Fortran Compiler for Linux* and Mac OS X*
Pat
Pat
Patrick_F_Intel1
I meant to say "if you post your questions" to the compiler forums.
David_B_24
OK, thanks. I'll try and find the correct forum.
