Configuring RAPL limits in Sandy Bridge Xeon processors
Nobin_M_
I am trying to set RAPL limits, so my question is for setting some power limits, do I need to go to each core and set the limits or just set limits in core 0 in a socket. each core I meant writing all the /dev/cpu/<N>/msr nodes in that socket?
Can we set different values in each of the cores in a socket.
-Nobin
Martin_D_Intel1
ok. I updated the tool to support your cpuid. I will email to you as well.
thanks
Martin
Nobin_M_
Hi Martin,
Thanks for the power_gov.
I am using a Ivy Bridge server chip which has 10 cores ( I work for some company).
my RAPL understanding lacks some fundamental knowledge, can you answer the below question.
Lets think only about PKG domain.
We have two power limits in MSR_PKG_POWER_LIMIT register for PKG domain, say power_limit1/time_window1 and power_limit2/time_window2.
We just go ahead and set values in MSR_PKG_POWER_LIMIT register, after it is upto the system to determine how to use it(i.e. when/which limit).
How system is going to use it?
After enabling(with clamping) both, system power consumption will be limited between power_limit1 and power_limi2?
What is the importance time_window1 and time_window2? how it is used?
-Nobin
MSR_PKG_POWER_LIMIT
Nobin_M_
Processor family datasheets are much more helpfull, than system programmers manuals. Processor family datasheets has much clear documentation about RAPL.
Bernard
Valued Contributor I
Can you point to some datasheets?
Thank you in advance
Nobin_M_
Intel® Xeon® Processor E5-1600/E5-2600/E5-4600 Product Families Datasheets Volume One
http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/xeon-e5-1600-2600-vol-1-datasheet.pdf
Bernard
Thank you Nobin:)
Vasileios_T_
Hello Martin,
I am trying to use the power governor tool on an Ivy Bridge server (Intel(R) Xeon(R) CPU E5-2680 v2), but I get:
PKG_0,Core_0,Graphics_0,Uncore_0,PKG_1,Core_1,Graphics_1,Uncore_1,
*** Error in `./power_gov': free(): invalid next size (normal): 0x0000000001d25770 ***
when I try to start the power meter.
Any ideas what could it be?
Vasileios.
