Custom counters file view out of memory error PCM-Service
Maurice_D_
hi,
I am getting a 'custom counters file view is out of memory' error when attempting to start the PCM-Service.
Anyone run into this? and where would I adjust the memory for it?  thanks
Thomas_W_Intel
PCM shouldn't use a lot of memory, so something must go totally wrong. Does the command-line version of PCM run correctly?
