How can I compile the MSR driver?
Antonio_v_
Hi all,
I'm just staritng using PCM on Windows 7. I was reading the WINDOWS_HOWTO.rtf file included in the library. I know that I have to compile and sign the driver, but I dont know how I have to do it. The only thing that i know I should use the DDK software from Microsoft. And I was looking for this software but I couldn´t find it, anyway I found another one called WDK.
So If you know how should I compile this driver, please give some tips.
Thanks in advance.
pengfei_w_Intel
could you give some detail info on how to build PCM.exe?
Patrick_F_Intel1
Hello pengfei,
Please don't post the same question mutiple times to multiple threads. This wastes people's time.
Pat
Bernard
Valued Contributor I
Hi pengfei
you can read this thread and find plenty of information on how to compile pcm.exe
Hausen_H_
After execute PCM-Srvice.exe, we got the error dialog with the folowing message, please tell us what's happening?
Windows Service Start Failure
Cannot start service from the command line or a degugger. A Windows Service mut first be installed(using installutil.exe) and then started with the ServiceExplorer, Windows Services Administrative tool or the NET SSTART command.
Bernard
>>>NET SSTART command.>>>
Did you try to issue this command net start <service name> ?
Anna_C_Intel
How could I build MSR.exe for win 10?
