ITT API fortran calls with Advisor
Paolo__
I would like to use the ITT library functions to delimit a part of my code where to collect Advisor data.
It is a fortran code compiled with IFORT version 2021.12.0 Package ID: w_oneAPI_2024.2.1.1083 (attached the VS project of a simple example).
I entered the following instructions:
USE ITTNOTIFY
call ITT_PAUSE()
call ITT_RESUME()
Including the library: libittnotify.lib
Setting the include directory path: $(ADVISOR_2025_DIR)\include\intel64
And the library directory path: $(ADVISOR_2025_DIR)\lib64
But I get the following error while linking:
Linking...
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_pause_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_PAUSE
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_resume_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_RESUME
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_thread_ignore_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_THREAD_IGNORE
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_suppress_push_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_SUPPRESS_PUSH
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_suppress_pop_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_SUPPRESS_POP
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_suppress_mark_range_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_SUPPRESS_MARK_RANGE
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_suppress_clear_range_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_SUPPRESS_CLEAR_RANGE
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_sync_prepare_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_SYNC_PREPARE
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_sync_cancel_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_SYNC_CANCEL
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_sync_acquired_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_SYNC_ACQUIRED
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_sync_releasing_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_SYNC_RELEASING
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_fsync_prepare_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_FSYNC_PREPARE
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_fsync_cancel_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_FSYNC_CANCEL
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_fsync_acquired_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_FSYNC_ACQUIRED
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_fsync_releasing_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_FSYNC_RELEASING
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_sync_destroy_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_SYNC_DESTROY
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_sync_createA_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_SYNC_CREATE
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_sync_renameA_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_SYNC_RENAME
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_thread_set_nameA_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_THREAD_SET_NAME
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_heap_record_memory_growth_begin_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_HEAP_RECORD_MEMORY_GROWTH_BEGIN
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_heap_record_memory_growth_end_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_HEAP_RECORD_MEMORY_GROWTH_END
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_heap_reset_detection_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_HEAP_RESET_DETECTION
libittnotify.lib(ittfortran.obj) : error LNK2019: unresolved external symbol ___itt_heap_record_ptr__3_0 referenced in function ITTNOTIFY_mp_ITT_HEAP_RECORD
x64\Release\TestITTLib.exe : fatal error LNK1120: 23 unresolved externals
