Intel Memory Latency Checker v3.9a BSOD W11
Shep
I'm getting a BSOD when using
--peak_injection_bandwidth
W11 - 22H2 - 22621.457
No OC.
MLC v3.9a
Not sure if it's my system or the MLC driver(mlcdrv.sys) failing ?
*                        Bugcheck Analysis                                    *
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000096, Exception code that caused the BugCheck
Arg2: fffff80485d850ec, Address of the instruction which caused the BugCheck
Arg3: ffffec061cb26bb0, Address of the context record for the exception that caused the BugCheck
Arg4: 0000000000000000, zero.
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1374
    Key  : Analysis.DebugAnalysisManager
    Value: Create
    Key  : Analysis.Elapsed.mSec
    Value: 2501
    Key  : Analysis.Init.CPU.mSec
    Value: 202
    Key  : Analysis.Init.Elapsed.mSec
    Value: 27550
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 97
    Key  : Bugcheck.Code.DumpHeader
    Value: 0x3b
    Key  : Bugcheck.Code.Register
    Value: 0x3b
    Key  : Dump.Attributes.AsUlong
    Value: 1808
    Key  : Dump.Attributes.KernelGeneratedTriageDump
    Value: 1
FILE_IN_CAB:  083022-7437-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x1808
  Kernel Generated Triage Dump
BUGCHECK_CODE:  3b
BUGCHECK_P1: c0000096
BUGCHECK_P2: fffff80485d850ec
BUGCHECK_P3: ffffec061cb26bb0
BUGCHECK_P4: 0
CONTEXT:  ffffec061cb26bb0 -- (.cxr 0xffffec061cb26bb0)
rax=0000000000000001 rbx=ffffdc047a99ac80 rcx=00000000000001a4
rdx=0000000000000000 rsi=00000000c000000d rdi=ffffdc047a99ad50
rip=fffff80485d850ec rsp=ffffec061cb275d0 rbp=ffffec061cb276a1
 r8=00007ff739dd6370  r9=ffffdc0479610e10 r10=fffff80485d85074
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000001 r15=ffffdc047b385e50
iopl=0         nv up ei pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00040246
mlcdrv+0x50ec:
fffff804`85d850ec 0f30            wrmsr
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  mlc.exe
STACK_TEXT:
ffffec06`1cb275d0 ffffdc04`7a1410c0     : 00007fff`ffff0000 00000000`00000000 fffff804`24146984 ffffdc04`79610e10 : mlcdrv+0x50ec
ffffec06`1cb275d8 00007fff`ffff0000     : 00000000`00000000 fffff804`24146984 ffffdc04`79610e10 fffff804`23c934a5 : 0xffffdc04`7a1410c0
ffffec06`1cb275e0 00000000`00000000     : fffff804`24146984 ffffdc04`79610e10 fffff804`23c934a5 ffffdc04`7a99ac80 : 0x00007fff`ffff0000
SYMBOL_NAME:  mlcdrv+50ec
MODULE_NAME: mlcdrv
IMAGE_NAME:  mlcdrv.sys
STACK_COMMAND:  .cxr 0xffffec061cb26bb0 ; kb
BUCKET_ID_FUNC_OFFSET:  50ec
FAILURE_BUCKET_ID:  0x3B_C0000096_mlcdrv!unknown_function
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {cb4fd739-7c8a-b5eb-084a-0780deb83b6d}
Followup:     MachineOwner
