Multicore prcessor uses through dot net programming
Kundan_Kumar
Can anyone guide us how toachieve multicore processor programming using dot net framework?
Patrick_F_Intel1
Hello Kundan,
You would probably have more success going after folks who do .net programming and ask them about using multiple threads.
I found one such site using google.
http://thedotnethub.blogspot.com/2010/04/introducing-net-40-parallel-programming.html
Hope this helps,
Pat
SergeyKostrov
Valued Contributor II
I recommend you to lookfor articleson MSDN. Here is a link:
http://msdn.microsoft.com/en-us/magazine/default.aspx
Sergey
SergeyKostrov
OKohl
.Net 4.0's "Parallel.For" will be a good place to start. Good Luck
Sefali
Hello Kundan
In the .NET framework 4+, there is enhanced support for parallel programming, including new class library types, Tasks, Parallel For, Parallel Linq, and concurrent collections. Check out some of these features here: multicore processor programming using dot net framework.
To help with the issue you can take the help of JumpGrowth, They have a dedicated team of analysts, designers, developers, and testers to create a .NET application with intuitive UX and modern UI. Their Custom Dot Net Development Services assure seamless workflow integration and superior quality web-based portals.
