1857 Discussions
Intel Performance Counter Monitor - Can't access PCI configuration space
Prabhu_T_
I'm trying to run the latest PCM 2.5 on a machine with Intel(R) Xeon(R) CPU E5-2670 (Sandy Bridge), but PCM gives the below message and do not show any memory read/write access in the report.
Can not access SNB-EP (Jaketown) PCI configuration space. Access to uncore counters (memory and QPI bandwidth) is disabled.
You must be root to access these SNB-EP counters in PCM
Can you please guide me what am I missing here.
1. I'm running PCM as root and also looked at the DELL BIOS options for performance counters related to PCI but could not find any to enable or disable
Thanks, Prabhu
Bernard
Valued Contributor I
It is related to Bios support.I do not think if in your case such a functionality is exposed to end user.Try to contact either DELL or Bios vendor.
McCalpinJohn
The "lspci" command under Linux will list all of the PCI configuration space ranges that the BIOS has made accessible.
These can be cross-referenced with the list in the "Intel® Xeon® Processor E5-2600 Product Family Uncore Performance Monitoring Guide"(Reference Number: 327043-001), to see exactly which devices and functions are missing.  This information will be helpful if you contact the system vendor about BIOS updates to enable these functions.
Bernard
And if you are on Windows you can use local kernel debugger to inspect pci configuration space with !pci command(tested on Win XP).
Prabhu_T_
Thank you for your suggestions Mr.John D. McCalpin and Mr. iliyapolak. I will try to contact the vendor for a BIOS update if available. But I have one more question, how is the Intel vtune amplifier 2013 is able to collect data for read/write of memory(Memory Access or Bandwidth analysis) and PCM cannot collect due to the above issue. If bios do not allow then VTune also shouldn't be collecting, Am I missing something ?. Please see below, the read and write is 0 for PCM.
Core (SKT) | EXEC | IPC  | FREQ  | AFREQ | L3MISS | L2MISS | L3HIT | L2HIT | L3CLK | L2CLK  | READ  | WRITE | TEMP
 TOTAL  *     0.15   1.05   0.15    1.15     511 K   1973 K    0.74    0.96    0.02    0.01    0.00    0.00     N/A
- Prabhu
Roman_D_Intel
Hi Prabhu,
could you please post the output of lspci command here to let me understand the issue better?
Roman
Prabhu_T_
Hi Roman,
Please see below for the output of lscpi command:
~/PCM2.5 # lspci
00:00.0 Host bridge: Intel Corporation Sandy Bridge DMI2 (rev 07)
00:01.0 PCI bridge: Intel Corporation Sandy Bridge IIO PCI Express Root Port 1a (rev 07)
00:02.0 PCI bridge: Intel Corporation Sandy Bridge IIO PCI Express Root Port 2a (rev 07)
00:02.2 PCI bridge: Intel Corporation Sandy Bridge IIO PCI Express Root Port 2c (rev 07)
00:03.0 PCI bridge: Intel Corporation Sandy Bridge IIO PCI Express Root Port 3a in PCI Express Mode (rev 07)
00:03.2 PCI bridge: Intel Corporation Sandy Bridge IIO PCI Express Root Port 3c (rev 07)
00:05.0 System peripheral: Intel Corporation Sandy Bridge Address Map, VTd_Misc, System Management (rev 07)
00:05.2 System peripheral: Intel Corporation Sandy Bridge Control Status and Global Errors (rev 07)
00:11.0 PCI bridge: Intel Corporation Patsburg PCI Express Virtual Root Port (rev 05)
00:16.0 Communication controller: Intel Corporation Patsburg HECI Controller #1 (rev 05)
00:16.1 Communication controller: Intel Corporation Patsburg HECI Controller #2 (rev 05)
00:1a.0 USB Controller: Intel Corporation Patsburg USB2 Enhanced Host Controller #2 (rev 05)
00:1c.0 PCI bridge: Intel Corporation Patsburg PCI Express Root Port 1 (rev b5)
00:1c.7 PCI bridge: Intel Corporation Patsburg PCI Express Root Port 8 (rev b5)
00:1d.0 USB Controller: Intel Corporation Patsburg USB2 Enhanced Host Controller #1 (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation Device 1d41 (rev 05)
00:1f.2 SATA controller: Intel Corporation Patsburg 6 Port SATA AHCI Controller (rev 05)
01:00.0 Ethernet controller: Intel Corporation Device 1521 (rev 01)
01:00.1 Ethernet controller: Intel Corporation Device 1521 (rev 01)
01:00.2 Ethernet controller: Intel Corporation Device 1521 (rev 01)
01:00.3 Ethernet controller: Intel Corporation Device 1521 (rev 01)
02:00.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS TB (rev 01)
08:00.0 PCI bridge: Renesas Technology Corp. SH7757 PCIe Switch [PS]
09:00.0 PCI bridge: Renesas Technology Corp. SH7757 PCIe Switch [PS]
09:01.0 PCI bridge: Renesas Technology Corp. SH7757 PCIe Switch [PS]
0a:00.0 PCI bridge: Renesas Technology Corp. SH7757 PCIe-PCI Bridge [PPB]
0b:00.0 VGA compatible controller: Matrox Graphics, Inc. G200eR2
3f:08.0 System peripheral: Intel Corporation Sandy Bridge QPI Link 0 (rev 07)
3f:09.0 System peripheral: Intel Corporation Sandy Bridge QPI Link 1 (rev 07)
3f:0a.0 System peripheral: Intel Corporation Sandy Bridge Power Control Unit 0 (rev 07)
3f:0a.1 System peripheral: Intel Corporation Sandy Bridge Power Control Unit 1 (rev 07)
3f:0a.2 System peripheral: Intel Corporation Sandy Bridge Power Control Unit 2 (rev 07)
3f:0a.3 System peripheral: Intel Corporation Device 3cd0 (rev 07)
3f:0b.0 System peripheral: Intel Corporation Sandy Bridge Interrupt Control Registers (rev 07)
3f:0b.3 System peripheral: Intel Corporation Sandy Bridge Semaphore and Scratchpad Configuration Registers (rev 07)
3f:0c.0 System peripheral: Intel Corporation Device 3ce8 (rev 07)
3f:0c.1 System peripheral: Intel Corporation Device 3ce8 (rev 07)
3f:0c.2 System peripheral: Intel Corporation Device 3ce8 (rev 07)
3f:0c.3 System peripheral: Intel Corporation Device 3ce8 (rev 07)
3f:0c.6 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller System Address Decoder 0 (rev 07)
3f:0c.7 System peripheral: Intel Corporation Sandy Bridge System Address Decoder (rev 07)
3f:0d.0 System peripheral: Intel Corporation Device 3ce8 (rev 07)
3f:0d.1 System peripheral: Intel Corporation Device 3ce8 (rev 07)
3f:0d.2 System peripheral: Intel Corporation Device 3ce8 (rev 07)
3f:0d.3 System peripheral: Intel Corporation Device 3ce8 (rev 07)
3f:0d.6 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller System Address Decoder 1 (rev 07)
3f:0e.0 System peripheral: Intel Corporation Sandy Bridge Processor Home Agent (rev 07)
3f:0e.1 Performance counters: Intel Corporation Sandy Bridge Processor Home Agent Performance Monitoring (rev 07)
3f:0f.0 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller Registers (rev 07)
3f:0f.1 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller RAS Registers (rev 07)
3f:0f.2 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller Target Address Decoder 0 (rev 07)
3f:0f.3 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller Target Address Decoder 1 (rev 07)
3f:0f.4 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller Target Address Decoder 2 (rev 07)
3f:0f.5 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller Target Address Decoder 3 (rev 07)
3f:0f.6 System peripheral: Intel Corporation Device 3cae (rev 07)
3f:10.0 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller Channel 0-3 Thermal Control 0 (rev 07)
3f:10.1 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller Channel 0-3 Thermal Control 1 (rev 07)
3f:10.2 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller ERROR Registers 0 (rev 07)
3f:10.3 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller ERROR Registers 1 (rev 07)
3f:10.4 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller Channel 0-3 Thermal Control 2 (rev 07)
3f:10.5 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller Channel 0-3 Thermal Control 3 (rev 07)
3f:10.6 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller ERROR Registers 2 (rev 07)
3f:10.7 System peripheral: Intel Corporation Sandy Bridge Integrated Memory Controller ERROR Registers 3 (rev 07)
3f:11.0 System peripheral: Intel Corporation Device 3cb8 (rev 07)
3f:13.0 System peripheral: Intel Corporation Sandy Bridge R2PCIe (rev 07)
3f:13.1 Performance counters: Intel Corporation Sandy Bridge Ring to PCI Express Performance Monitor (rev 07)
3f:13.4 Performance counters: Intel Corporation Sandy Bridge QuickPath Interconnect Agent Ring Registers (rev 07)
3f:13.5 Performance counters: Intel Corporation Sandy Bridge Ring to QuickPath Interconnect Link 0 Performance Monitor (rev 07)
3f:13.6 System peripheral: Intel Corporation Sandy Bridge Ring to QuickPath Interconnect Link 1 Performance Monitor (rev 07)
Thanks,Prabhu
Roman_D_Intel
Prabhu,
does your system have single processor (socket) ?
Roman
Bernard
>?>>Can not access SNB-EP (Jaketown) PCI configuration space. Access to uncore counters (memory and QPI bandwidth)>>>
Does it mean device 8 and 9 cannot be read?
Prabhu_T_
Roman, The system has single processor only.
Prabhu
Bernard
>>> Intel vtune amplifier 2013 is able to collect data for read/write of memory(Memory Access or Bandwidth analysis) and PCM cannot collect due to the above issue>>>
Do you mean to  access pci address space?
Roman_D_Intel
Prabhu,
it seems that some low-level topology registers on your system have not been setup correctly by the BIOS. I will provide you a software workaround for PCM shortly.
Roman
Roman_D_Intel
Prabhu,
could you please apply the attached patch.txt ?
[bash]
cd IntelPerformanceCounterMonitorV2.5
patch < patch.txt
[/bash]
It should enable the integrated memory controller statistics. The QPI statistics are still hidden by your BIOS. But probably you don't need QPI stats anyway because you have a single socket system (QPI links usually connect processors/sockets).
Please try it and let me know if memory bandwidth counters work or not. You can generate memory traffic with the memoptest utility in PCM:
[bash]
make memoptest
./memoptest 0
[/bash]
Roman
Prabhu_T_
Hi Roman,
Thanks, I have installed your patch.  Below is the output of ./memoptest 0. But read and write from memory controller in PCM output did not change.
Elements data size: 203125 KB
Reading memory
Bandwidth: 2446.06 MByte/sec
Reading memory
Reading memory
Bandwidth: 1854.13 MByte/sec
I have build the entire PCM again and I have expected READ/WRITE in the output of the pcm.x would show the read and write from memory controller(still shows zero). But I think this patch has fixed the "Instructions per nominal CPU cycle" marked in the below output of pcm and don't know if the patch is relavent to this.
TOTAL * 1.10 0.95 1.15 1.15 4489 K 11 M 0.60 0.95 0.02 0.01 0.00 0.00 N/A
Instructions retired: 45 G ; Active cycles: 48 G ; Time (TSC): 2610 Mticks ; C0 (active,non-halted) core residency: 100.00 %
C1 core residency: 0.00 %; C3 core residency: 0.00 %; C6 core residency: 0.00 %; C7 core residency: 0.00 %
C2 package residency: 0.00 %; C3 package residency: 0.00 %; C6 package residency: 0.00 %; C7 package residency: 0.00 %
PHYSICAL CORE IPC : 1.91 => corresponds to 47.70 % utilization for cores in active state
Instructions per nominal CPU cycle: 2.20 => corresponds to 55.04 % core utilization over time interval
Thanks, Prabhu
Bernard
@Roman
what x86 instruction(s) are used to read memory? Is this rep movsb?
Roman_D_Intel
Prabhu,
Could you please post the full output for
[plain]
./pcm.x "sleep 1"
lspci -vvv
[/plain]
Roman
Roman_D_Intel
Since it is a lot of data you can better attach it to your post. Thanks, Roman
Bernard
>>>Instructions per nominal CPU cycle: 2.20 => corresponds to 55.04 % core utilization over time interval>>>
It could be interested to see the exact breakdown of executed instructions.It can be provided by VTune.
Roman_D_Intel
@iliyapolak
I use C++ std::find scan operation on array of structures (integer key + data). It does a few accesses per cache line on the keys (each access for a key is 4-bytes). I believe the compiler should generate normal integer mov instructions without the rep prefix in this case. I am not saying it is the most efficient way to generate read traffic (but a simple one using higher-level C++).
Roman
Bernard
Thanks for answer.I thought that you were using memcpy() instruction to move data from/to large int arrays. Afaik memcpy() is translated to rep movsd when the type is int.
Prabhu_T_
Hi Roman, Please find the outputs
1) ./pcm.x "sleep 1"
Intel(r) Performance Counter Monitor V2.5 (2013-06-04 11:44:11 +0200 ID=23faaad)
Copyright (c) 2009-2012 Intel Corporation
Num logical cores: 16
Num sockets: 1
Threads per core: 2
Core PMU (perfmon) version: 3
Number of core PMU generic (programmable) counters: 4
Width of generic (programmable) counters: 48 bits
Number of core PMU fixed counters: 3
Width of fixed counters: 48 bits
Nominal core frequency: 2600000000 Hz
Package thermal spec power: 115 Watt; Package minimum power: 51 Watt; Package maximum power: 180 Watt;
You must be root to access these SNB-EP counters in PCM.
Using PCM on your system might have a performance impact as per http://software.intel.com/en-us/articles/performance-impact-when-sampling-certain-llc-events-on-snb-ep-with-vtune
You can avoid the performance impact by using the option --noJKTWA, however the cache metrics might be wrong then.
Detected Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz "Intel(r) microarchitecture codename Sandy Bridge-EP/Jaketown"
Executing "sleep 1" command:
Exit code: 0
EXEC : instructions per nominal CPU cycle
IPC : instructions per CPU cycle
FREQ : relation to nominal CPU frequency='unhalted clock ticks'/'invariant timer ticks' (includes Intel Turbo Boost)
AFREQ : relation to nominal CPU frequency while in active state (not in power-saving C state)='unhalted clock ticks'/'invariant timer ticks while in C0-state' (includes Intel Turbo Boost)
L3MISS: L3 cache misses
L2MISS: L2 cache misses (including other core's L2 cache *hits*)
L3HIT : L3 cache hit ratio (0.00-1.00)
L2HIT : L2 cache hit ratio (0.00-1.00)
L3CLK : ratio of CPU cycles lost due to L3 cache misses (0.00-1.00), in some cases could be >1.0 due to a higher memory latency
L2CLK : ratio of CPU cycles lost due to missing L2 cache but still hitting L3 cache (0.00-1.00)
READ : bytes read from memory controller (in GBytes)
WRITE : bytes written to memory controller (in GBytes)
TEMP : Temperature reading in 1 degree Celsius relative to the TjMax temperature (thermal headroom): 0 corresponds to the max temperature
0 0 0.75 0.66 1.14 1.15 181 K 596 K 0.70 0.99 0.01 0.01 N/A N/A 48
1 0 0.74 0.65 1.14 1.15 131 K 561 K 0.77 0.99 0.01 0.01 N/A N/A 45
2 0 0.74 0.65 1.13 1.15 133 K 509 K 0.74 0.99 0.01 0.00 N/A N/A 50
3 0 0.75 0.66 1.13 1.15 163 K 577 K 0.72 0.99 0.01 0.01 N/A N/A 45
4 0 0.74 0.65 1.14 1.15 127 K 510 K 0.75 0.99 0.01 0.00 N/A N/A 47
5 0 0.73 0.64 1.14 1.15 135 K 512 K 0.74 0.99 0.01 0.00 N/A N/A 44
6 0 0.75 0.66 1.13 1.15 134 K 529 K 0.75 0.99 0.01 0.00 N/A N/A 43
7 0 0.76 0.67 1.13 1.15 160 K 562 K 0.72 0.99 0.01 0.01 N/A N/A 43
8 0 0.75 0.66 1.14 1.15 204 K 625 K 0.67 0.99 0.01 0.01 N/A N/A 48
9 0 0.74 0.65 1.14 1.15 129 K 536 K 0.76 0.99 0.01 0.01 N/A N/A 45
10 0 0.74 0.65 1.14 1.15 120 K 513 K 0.77 0.99 0.01 0.00 N/A N/A 50
11 0 0.74 0.66 1.13 1.15 171 K 578 K 0.70 0.99 0.01 0.01 N/A N/A 45
12 0 0.74 0.65 1.15 1.15 121 K 512 K 0.76 0.99 0.01 0.00 N/A N/A 47
13 0 0.74 0.64 1.15 1.15 142 K 543 K 0.74 0.99 0.01 0.00 N/A N/A 44
14 0 0.76 0.67 1.14 1.15 134 K 536 K 0.75 0.99 0.01 0.00 N/A N/A 43
15 0 0.72 0.65 1.10 1.15 136 K 520 K 0.74 0.99 0.01 0.00 N/A N/A 43
SKT 0 0.74 0.65 1.13 1.15 2327 K 8727 K 0.73 0.99 0.01 0.00 0.00 0.00 43
TOTAL * 0.74 0.65 1.13 1.15 2327 K 8727 K 0.73 0.99 0.01 0.00 0.00 0.00 N/A
Instructions retired: 31 G ; Active cycles: 47 G ; Time (TSC): 2609 Mticks ; C0 (active,non-halted) core residency: 98.36 %
C1 core residency: 1.64 %; C3 core residency: 0.00 %; C6 core residency: 0.00 %; C7 core residency: 0.00 %
PHYSICAL CORE IPC : 1.31 => corresponds to 32.73 % utilization for cores in active state
Instructions per nominal CPU cycle: 1.49 => corresponds to 37.14 % core utilization over time interval
SKT 0 package consumed 99.46 Joules
TOTAL: 99.46 Joules
SKT 0 DIMMs consumed 16.49 Joules
TOTAL: 16.49 Joules
Cleaning up
2)  lspci -vvv
Subsystem: Dell Device 048c
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 0
Capabilities: [90] Express (v2) Root Port (Slot-), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x4, ASPM L0s L1, Latency L0 <512ns, L1 <4us
ClockPM- Surprise+ LLActRep+ BwNot+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed unknown, Width x0, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
RootCtl: ErrCorrectable- ErrNon-Fatal+ ErrFatal+ PMEIntEna- CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range BCD, TimeoutDis+ ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- ARIFwd-
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [e0] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [100] Vendor Specific Information <?>
Capabilities: [144] Vendor Specific Information <?>
Capabilities: [1d0] Vendor Specific Information <?>
Capabilities: [280] Vendor Specific Information <?>
00:01.0 PCI bridge: Intel Corporation Sandy Bridge IIO PCI Express Root Port 1a (rev 07) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Latency: 0, Cache Line Size: 64 bytes
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000f000-0000ffff
Memory behind bridge: dc000000-dcffffff
Prefetchable memory behind bridge: 00000000c2000000-00000000c21fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity+ SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: Dell Device 048c
Capabilities: [60] MSI: Mask+ 64bit- Count=1/2 Enable-
Address: fee01004 Data: 40c9
Masking: 00000003 Pending: 00000000
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
DevCtl: Report errors: Correctable- Non-Fatal+ Fatal+ Unsupported+
MaxPayload 256 bytes, MaxReadReq 128 bytes
LnkCap: Port #1, Speed 8GT/s, Width x8, ASPM L1, Latency L0 unlimited, L1 <16us
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
RootCtl: ErrCorrectable- ErrNon-Fatal+ ErrFatal+ PMEIntEna- CRSVisible+
DevCap2: Completion Timeout: Range BCD, TimeoutDis+ ARIFwd+
DevCtl2: Completion Timeout: 65ms to 210ms, TimeoutDis- ARIFwd-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
Capabilities: [110] Access Control Services
ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [148] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt+ UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol+
UESvrt: DLP+ SDES+ TLP+ FCP+ CmpltTO+ CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ NonFatalErr+
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [250] #19
Kernel driver in use: pcieport-driver
Kernel modules: shpchp
00:02.0 PCI bridge: Intel Corporation Sandy Bridge IIO PCI Express Root Port 2a (rev 07) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000f000-00000fff
Memory behind bridge: fff00000-000fffff
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
Address: fee01004 Data: 40d1
Capabilities: [90] Express (v2) Root Port (Slot+), MSI 00
LnkCap: Port #3, Speed 8GT/s, Width x8, ASPM L1, Latency L0 unlimited, L1 <16us
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled+ Retrain- CommClk-
LnkSta: Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surpise-
Slot # 5, PowerLimit 25.000000; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd Off, Power+ Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
Changed: MRL- PresDet+ LinkState-
00:02.2 PCI bridge: Intel Corporation Sandy Bridge IIO PCI Express Root Port 2c (rev 07) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: dd000000-ddffffff
Address: fee01004 Data: 40d9
LnkCap: Port #5, Speed 8GT/s, Width x8, ASPM L1, Latency L0 unlimited, L1 <16us
ClockPM- Surprise+ LLActRep+ BwNot-
LnkSta: Speed 5GT/s, Width x8, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
00:03.0 PCI bridge: Intel Corporation Sandy Bridge IIO PCI Express Root Port 3a in PCI Express Mode (rev 07) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Address: fee01004 Data: 40e1
ExtTag+ RBE+ FLReset-
LnkCap: Port #7, Speed 8GT/s, Width x8, ASPM L1, Latency L0 unlimited, L1 <16us
Slot # 6, PowerLimit 25.000000; Interlock- NoCompl-
00:03.2 PCI bridge: Intel Corporation Sandy Bridge IIO PCI Express Root Port 3c (rev 07) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
Address: fee01004 Data: 40e9
LnkCap: Port #9, Speed 8GT/s, Width x8, ASPM L1, Latency L0 unlimited, L1 <16us
Slot # 7, PowerLimit 25.000000; Interlock- NoCompl-
Capabilities: [40] Express (v2) Root Complex Integrated Endpoint, MSI 00
ExtTag- RBE- FLReset-
LnkCap: Port #0, Speed unknown, Width x0, ASPM unknown, Latency L0 <64ns, L1 <1us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; Disabled- Retrain- CommClk-
DevCap2: Completion Timeout: Not Supported, TimeoutDis-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal+ Unsupported-
00:11.0 PCI bridge: Intel Corporation Patsburg PCI Express Virtual Root Port (rev 05) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
Capabilities: [40] Express (v2) Root Port (Slot-), MSI 00
MaxPayload 128 bytes, MaxReadReq 512 bytes
LnkCap: Port #17, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <64ns, L1 <1us
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis- ARIFwd+
Capabilities: [80] Power Management version 3
Capabilities: [88] Subsystem: Dell Device 048c
Capabilities: [90] MSI: Mask- 64bit- Count=1/1 Enable-
Address: fee01004 Data: 4032
Capabilities: [100] Advanced Error Reporting
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol+
UESvrt: DLP+ SDES- TLP+ FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
Capabilities: [138] Access Control Services
ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl- DirectTrans+
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx+
Latency: 0
Region 0: Memory at c2200000 (64-bit, non-prefetchable) [size=16]
Capabilities: [50] Power Management version 3
Capabilities: [8c] MSI: Mask- 64bit+ Count=1/1 Enable-
Address: 0000000000000000 Data: 0000
Latency: 0
Region 0: Memory at c2200010 (64-bit, non-prefetchable) [size=16]
00:1a.0 USB Controller: Intel Corporation Patsburg USB2 Enhanced Host Controller #2 (rev 05) (prog-if 20 [EHCI])
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 130
Region 0: Memory at df8fd000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [50] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [58] Debug port: BAR=1 offset=00a0
Capabilities: [98] PCIe advanced features <?>
Kernel driver in use: ehci_hcd
Kernel modules: ehci-hcd
00:1c.0 PCI bridge: Intel Corporation Patsburg PCI Express Root Port 1 (rev b5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #1, Speed 5GT/s, Width x4, ASPM L0s L1, Latency L0 <1us, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot-
DevCap2: Completion Timeout: Range BC, TimeoutDis+ ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
Capabilities: [80] MSI: Mask- 64bit- Count=1/1 Enable-
Address: fee01004 Data: 403a
Capabilities: [90] Subsystem: Dell Device 048c
Capabilities: [a0] Power Management version 2
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt+ UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
UESvrt: DLP+ SDES- TLP+ FCP- CmpltTO+ CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
00:1c.7 PCI bridge: Intel Corporation Patsburg PCI Express Root Port 8 (rev b5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=08, subordinate=0c, sec-latency=0
Memory behind bridge: de000000-df7fffff
Prefetchable memory behind bridge: 00000000d8000000-00000000d8ffffff
BridgeCtl: Parity+ SERR+ NoISA- VGA+ MAbort- >Reset- FastB2B-
LnkCap: Port #8, Speed 5GT/s, Width x1, ASPM L0s L1, Latency L0 <512ns, L1 <4us
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
Address: fee01004 Data: 4042
00:1d.0 USB Controller: Intel Corporation Patsburg USB2 Enhanced Host Controller #1 (rev 05) (prog-if 20 [EHCI])
Latency: 0
Interrupt: pin A routed to IRQ 138
Region 0: Memory at df8fe000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5) (prog-if 01 [Subtractive decode])
Latency: 0
Bus: primary=00, secondary=0d, subordinate=0d, sec-latency=32
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
Capabilities: [50] Subsystem: Dell Device 048c
Kernel modules: hw_random
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Capabilities: [e0] Vendor Specific Information <?>
00:1f.2 SATA controller: Intel Corporation Patsburg 6 Port SATA AHCI Controller (rev 05) (prog-if 01 [AHCI 1.0])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 122
Region 0: I/O ports at dce8 [size=8]
Region 1: I/O ports at dcf8 [size=4]
Region 2: I/O ports at dcf0 [size=8]
Region 3: I/O ports at dcfc [size=4]
Region 4: I/O ports at dcc0 [size=32]
Region 5: Memory at df8ff000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [80] MSI: Mask- 64bit- Count=1/1 Enable+
Address: fee1f004 Data: 407a
Capabilities: [70] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
Capabilities: [a8] SATA HBA <?>
Capabilities: [b0] PCIe advanced features <?>
Kernel driver in use: ahci
Kernel modules: ahci
Subsystem: Dell Device 1f60
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Interrupt: pin D routed to IRQ 154
Region 0: Memory at dcb00000 (32-bit, non-prefetchable) [size=1M]
Region 2: I/O ports at fc80 [size=32]
Region 3: Memory at dcff0000 (32-bit, non-prefetchable) [size=16K]
Expansion ROM at dc000000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Mask+ 64bit+ Count=1/1 Enable+
Address: 00000000fee0f004 Data: 409a
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable- Mask- TabSize=10
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00002000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Latency L0 <4us, L1 <32us
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+
Capabilities: [e0] Vital Product Data
Not readable
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt+ UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP+ FCP+ CmpltTO+ CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC+ UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140] Device Serial Number 4f-c1-f3-ff-ff-5b-30-bc
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [1a0] #17
Capabilities: [1c0] #18
Capabilities: [1d0] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Kernel driver in use: igb
Kernel modules: igb
Interrupt: pin C routed to IRQ 170
Region 0: Memory at dcc00000 (32-bit, non-prefetchable) [size=1M]
Region 2: I/O ports at fca0 [size=32]
Region 3: Memory at dcff4000 (32-bit, non-prefetchable) [size=16K]
Expansion ROM at c2000000 [disabled] [size=512K]
Address: 00000000fee1f004 Data: 40aa
Not readable
ARICap: MFVC- ACS-, Next Function: 2
Kernel modules: igb
Interrupt: pin B routed to IRQ 186
Region 0: Memory at dcd00000 (32-bit, non-prefetchable) [size=1M]
Region 2: I/O ports at fcc0 [size=32]
Region 3: Memory at dcff8000 (32-bit, non-prefetchable) [size=16K]
Expansion ROM at c2080000 [disabled] [size=512K]
Address: 00000000fee2f004 Data: 40ba
Not readable
ARICap: MFVC- ACS-, Next Function: 3
Kernel modules: igb
Interrupt: pin A routed to IRQ 202
Region 0: Memory at dce00000 (32-bit, non-prefetchable) [size=1M]
Region 2: I/O ports at fce0 [size=32]
Region 3: Memory at dcffc000 (32-bit, non-prefetchable) [size=16K]
Expansion ROM at c2100000 [disabled] [size=512K]
Address: 00000000fee3f004 Data: 40ca
Not readable
ARICap: MFVC- ACS-, Next Function: 0
Kernel modules: igb
Subsystem: Dell PERC H510 Mini (for monolithics)
Interrupt: pin A routed to IRQ 98
Region 0: I/O ports at ec00 [size=256]
Region 1: Memory at ddffc000 (64-bit, non-prefetchable) [size=16K]
Region 3: Memory at ddf80000 (64-bit, non-prefetchable) [size=256K]
Expansion ROM at dd000000 [disabled] [size=128K]
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [68] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 4096 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
LnkCap: Port #0, Speed 5GT/s, Width x8, ASPM L0s, Latency L0 <64ns, L1 <1us
LnkSta: Speed 5GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Capabilities: [d0] Vital Product Data
Not readable
Capabilities: [a8] MSI: Mask- 64bit+ Count=1/1 Enable-
Capabilities: [c0] MSI-X: Enable+ Mask- TabSize=16
Vector table: BAR=1 offset=00002000
PBA: BAR=1 offset=00003000
Capabilities: [1e0] #19
Capabilities: [1c0] Power Budgeting <?>
Capabilities: [190] #16
Capabilities: [148] Alternative Routing-ID Interpretation (ARI)
Kernel driver in use: megaraid_sas
Kernel modules: megaraid_sas
08:00.0 PCI bridge: Renesas Technology Corp. SH7757 PCIe Switch [PS] (prog-if 00 [Normal decode])
BIST result: 00
Bus: primary=08, secondary=09, subordinate=0c, sec-latency=0
Capabilities: [50] MSI: Mask- 64bit+ Count=1/1 Enable-
Address: 00000000fee01004 Data: 404a
Capabilities: [70] Express (v2) Upstream Port, MSI 00
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-SlotPowerLimit 0.000000W
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Latency L0 unlimited, L1 unlimited
LnkCtl: ASPM Disabled; Disabled- Retrain- CommClk+
UESvrt: DLP+ SDES+ TLP+ FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC+ UnsupReq- ACSViol-
09:00.0 PCI bridge: Renesas Technology Corp. SH7757 PCIe Switch [PS] (prog-if 00 [Normal decode])
BIST result: 00
Bus: primary=09, secondary=0a, subordinate=0b, sec-latency=0
Memory behind bridge: de000000-deffffff
Address: 00000000fee01004 Data: 4052
Capabilities: [70] Express (v2) Downstream Port (Slot-), MSI 00
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM unknown, Latency L0 unlimited, L1 unlimited
DevCap2: Completion Timeout: Not Supported, TimeoutDis- ARIFwd-
09:01.0 PCI bridge: Renesas Technology Corp. SH7757 PCIe Switch [PS] (prog-if 00 [Normal decode])
BIST result: 00
Bus: primary=09, secondary=0c, subordinate=0c, sec-latency=0
Memory behind bridge: df700000-df7fffff
Address: 00000000fee01004 Data: 405a
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM unknown, Latency L0 unlimited, L1 unlimited
Capabilities: [150] Access Control Services
0a:00.0 PCI bridge: Renesas Technology Corp. SH7757 PCIe-PCI Bridge [PPB] (prog-if 00 [Normal decode])
BIST result: 00
Bus: primary=0a, secondary=0b, subordinate=0b, sec-latency=0
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [70] Express (v2) PCI/PCI-X Bridge, MSI 00
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ BrConfRtry-
DevSta: CorrErr+ UncorrErr+ FatalErr- UnsuppReq+ AuxPwr- TransPend-
0b:00.0 VGA compatible controller: Matrox Graphics, Inc. G200eR2 (prog-if 00 [VGA controller])
Latency: 64 (4000ns min, 8000ns max), Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 11
Region 0: Memory at d8000000 (32-bit, prefetchable) [size=16M]
Region 1: Memory at deffc000 (32-bit, non-prefetchable) [size=16K]
Region 2: Memory at de000000 (32-bit, non-prefetchable) [size=8M]
Expansion ROM at <unassigned> [disabled]
Capabilities: [dc] Power Management version 1
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Subsystem: Intel Corporation Device 0000
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Capabilities: [40] Express (v1) Root Complex Integrated Endpoint, MSI 00
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
