Software Tuning, Performance Optimization & Platform Monitoring
Discussion regarding monitoring and software tuning methodologies, Performance Monitoring Unit (PMU) of Intel microprocessors, and platform updating.
MEM_UOP_RETIRED. LOADS & MEM_UOP_RETIRED. STORES
GHui
新手
1,088 次查看
I want to collect MEM_UOP_RETIRED. LOADS and MEM_UOP_RETIRED. STORES events. I used "perf stat -e r01D0 -e r02D0 ./stream" to test. But I get event's value is zero. I dont't known how this happened.
OS: rhel6.1
HardPlatform: vendor_id: GenuineIntelcpu family: 6model: 45model name: Intel Xeon CPU E5-2680 0 @ 2.70GHzstepping: 6cpuid level: 13
EventNum. | UmaskValue | EventMaskMnemonic | Description | Comment
D0H | 01H |MEM_UOP_RETIRED.LOADS | Qualify retired memory uops that are loads. Combine with umask 10H,20H, 40H, 80H. | Supports PEBS
D0H | 02H |MEM_UOP_RETIRED.STORES | Qualify retired memory uops that are stores. Combine with umask 10H, 20H, 40H, 80H. |
I get the doucument from http://download.intel.com/products/processor/manual/325462.pdf, at page 3121/4128.
0 项奖励
5 回复数
GHui
新手
1,088 次查看
And may I consider the two events (MEM_UOP_RETIRED. LOADS & MEM_UOP_RETIRED. STORES) as memory bandwidth?
0 项奖励
Patrick_F_Intel1
1,088 次查看
Hello GHui,
You need to use the umask '0x81' for loads and 0x82 for stores.
From the SDM vol 3:
evt=D0H, umask=80H, MEM_UOP_RETIRED.ALL ; Qualify any retired memory uops.; Must combine with umask 01H, 02H, to produce counts.
So for loads use '-r81d0' and for stores use -r82d0.
The events just countloads and stores uops, not necessarily loads and stores that go all the way to DRAM.
And, probably unless your code is hand coded assembly (where you KNOW that all the loads go to DRAM, no register spills, reloading of registers etc) then probably most loads and stores don't go memory(DRAM).
Pat
0 项奖励
GHui
新手
1,088 次查看
Yes, it worked. Thank you.
(240257946213*64*10e-9 + 120170251833*64*10e-9)/165.653999299 = 139.250514763052
I calc the MemoryBandwidt is 139GB/sec, is that correct according to the stream log?
The output log follow:
Function Rate (MB/s) Avg time Min time Max time
Copy: 14224.0068 0.0068 0.0067 0.0071
Scale: 13815.0410 0.0070 0.0069 0.0073
Add: 15270.5243 0.0095 0.0094 0.0099
Triad: 14748.1204 0.0098 0.0098 0.0101
Solution Validates
Performance counter stats for './stream':
240257946213 raw 0x81d0
120170251833 raw 0x82d0
165.653999299 seconds time elapsed
0 项奖励
GHui
新手
1,088 次查看
I also tested Linpak.
(3007370989069*64*10e-9 + 96836841041*64*10e-9)/143.245665508 = 1386.913177599393
The result is so big that I think there is something wrong with my formula.
[cpp]The linpak log following: ---------- [ user ]$ perf stat -e r81d0 -e r82d0 ./linpack ... ... ... ... 3007370989069 raw 0x81d0 96836841041 raw 0x82d0 143.245665508 seconds time elapsed[/cpp]
0 项奖励
Patrick_F_Intel1
1,088 次查看
The only way you can use these events to count memory bandwidth is if you are SURE that every load and store uop actually misses the L3.
Your results indicate that most of the load and store uops are hitting the cache.
Pat
0 项奖励
回复
