Memory Bandwidth - stream and Intel MLC
James_M_3
Using the stream code, and Intel's MLC, I observe a large difference in reported memory bandwidth.
stream reports -  Copy: 13041, Scale: 12850, Add: 14436, Triad: 14340
Intel's MLC reports - ALL Reads: 75823, 3:1 Reads-Writes: 74216, 2:1 Reads-Writes: 73818, 1:1 Reads-Writes: 69407 and Stream-triad like: 70701.
So the MLC Stream-triad like value is 70.7GB/sec, versus stream triad 14.3GB/sec.
I am curious to understand the difference. Is it because of concurrency? MLC spawns several threads. I did not compile stream with OpenMP, so it is executing as a single thread.
Thanks and best regards
Jim
McCalpinJohn
Yes, the primary difference is concurrency.
The size of the difference will depend on the system under test (both the physical configuration (model, #sockets, #DIMMS/channel) and the BIOS configuration (snooping mode, memory redundancy mode, etc)) and on how STREAM was compiled and run.
James_M_3
Makes sense. Thanks much.
Jim
tian__yvan
Can you offer the results of mlc and stream/stream_omp under the same system under test?
