[PCM] building OS X driver fails
Thomas_W_Intel
Danilcha D commented on the Intel PCM article::
Hello!
Could you please help me?
I was building the OS X driver and it failed:
Check dependencies
[BEROR]error: There is no SDK with the name or path '.../IntelPerformanceCounterMonitorV2.8/MacMSRDriver/macosx10.8'
I'm on OS X Mavericks (10.9.5), XCode 6.2.
I'm posting this to the forum, hoping that some of the Apple user can answer it.
Kind regards
Thomas
Danilcha
Thank you, Thomas!
I did it as described in https://software.intel.com/en-us/forums/topic/533393 — changed in Xcode SDK to 10.9 and removed the search path.
Caught a kernel panic in the driver then after running pcm.x for a minute.
Patrick_F_Intel1
Hello Danicha,
Also see https://software.intel.com/en-us/comment/1822905#comment-1822905
In particular:
I also had to comment out the call to freeRMID() in the PCM::cleanup() routine in cpucounters.cpp.
If freeRMID() is not commented out then my Mac crashes when I hit control-C while running pcm.x. I believe that the next version of PCM will avoid calling freeRMID() on systems which don't have the RMID MSRs.
JAlex2
One of the Best Bandwidth Monitoring Tools which I know are
  1. BitMeter OS
  2. FreeMeter Bandwidth Monitor
  3. ShaPlus Bandwidth Meter
  4. BandwidthD
  5. PRTG Bandwidth Monitor
source:- http://merabheja.com/bandwidth-monitoring-tools/
