PMC Errata Handling
Gregory
I've recently discovered some of my chips were affected by some of the PMC errata out there.
Is there an easy way to go searching for which chipsets are affected, other than digging through each and every single family spec update doc?  Is there an errata database anywhere available behind a paywall or something?
I haven't had much luck in catching all the different errata that affect our many processors, in part due to how labor intensive it is to keep up with spec update releases and combing through everything manually.
Just looking for resources,
~Gregory
