1857 Discussions
Passing some memory boundary values to 'prefetcht*' instructions
SergeyKostrov
Valued Contributor II
What happens if some memory boundary values, like 0x00000000 or 0xFFFFFFFF, are passed to 'prefetcht*' instructions on a 32-bit platform?
Here is an example:
_mm_prefetch( 0xFFFFFFFF, _MM_HINT_T0);
Sergey
Patrick_F_Intel1
Hello Sergey,
Sorry for the delay.
The prefetch* instructions will not raise an exception for an invalid address but there will be a slight performance penalty.
The penalty varies on existing processors, but it derives from the need to walk the page tables in order to determine that a given address is invalid.
Note that SDM instruction set reference does not list the #PF (invalid address) exception for the prefetch* instructions indicating that this instruction doesn't raise the #PF exception.
I hope this helps,
Pat
Patrick_F_Intel1
Hello Sergey,
I did a quick test on 64bit windows platform andthe exceptions don't getdelivered back to my program.
I did a loop of:
xor rax,rax
prefetcht0 [rax]
I think the exceptions get squished (not delivered back to the app) but there is a penalty.
The performance seems to be about equal to a trip to memory per reference on my "processor formerly codenamed Westmere"-based laptop.
I will check with others after the holidays.
Pat
SergeyKostrov
Pat
Thank you, Patrick, and Merry Christmas!
PS: It would be good to see more technical details later...
Patrick_F_Intel1
Merry Christmas and happy holidays to you too!
SergeyKostrov
>>xor rax,rax
>>prefetcht0 [rax]
Hi Patrick, I simply would like to follow up. You mentioned some exceptions. Do you mean
some internal CPU exceptions, or some exceptions from anoperating system?
Could provide a little bit more technicaldetails, please?
Sergey
Patrick_F_Intel1
Hello Sergey,
I hope this helps,
Pat
k_sarnath
Just to add:
This is because an invalid address will not be present in the TLB(Supfast bufferfor Vto P translation).
So, the TLB miss will cause the page-table walk and hence the penalty..
