Performance Monitoring for E3-1268L V5
Richard_B_
Can someone please point me to the reference that is needed to monitor the performance of the E3-1268L V5 processor. I have found the following references but I am not sure which one applies (if either):
- Intel Xeon Processor E7 Family Uncore Programming Guide
- Intel Xeon Processor Scalable Memory Family Uncore Performance Monitoring
If there are code snippets to monitor ECC memory performance that would also be appreciated. I am using a non-Windows OS.
Thanks for the help in advance,
Richard
McCalpinJohn
The Xeon E3 processors use the same uncore as the Core i7 processors of the same generation.
Note that these counters are 32 bits wide, and that they aggregate over the two DRAM channels, so they wrap quite quickly.  I have not had my second cup of coffee yet, but my calculator suggests that 2 channels of DDR4-2133 should be able to increment pow(2,32) bits in about 8 seconds, so a sampling period of under 8 seconds is required to unambiguously detect and correct for wrap-around.
