Performance of a particular process using perfmon
Vijetha_Y_Intel
Hi All
I need to check CPU usage of a process [powershell.exe] which gets triggered once in every 3mins through a scheduler. When i use perfmon, i could select powershell but only one instance of it as pid is concatenated [powershell_<PID>]. By the time i select the powershell process, and change the scale, the script would have executed. I need to monitor it countinously for a period of time
Is there a way that i can monitor at process name level and not at process level,
