- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hi everyone,
When I tried to use Power Governor(https://software.intel.com/en-us/articles/intel-power-governor) and Power Gadget(https://software.intel.com/en-us/articles/intel-power-gadget-20) to get the power consumption info of CPU, I got the following error:
RAPL not supported, or machine model 306f2 not recognized.
Init failed!
When I followed the README.md to "modprobe msr" and "modprobe cpuid", it shows:
FATAL: Module mrs not found.
FATAL: Module cpuid not found.
I found any posts in the forum but didn't find any problems like this.
The Purpose is to get the power consumption/temp info in a program.
Does anyone have any ideas how to deal with the problems above of these two tools or other methods to get the power consumption in a program?
Best wishes,
Jiawen
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
With that details, I believe your "DisplayFamily_DisplayModel" is 06_3FH.
Well, just checked on the Intel® 64 and IA-32 Architectures Software Developer’s Manual Documentation by that ID and I find RAPL registers available...
Try running this sample code: http://web.eece.maine.edu/~vweaver/projects/rapl/ (Userspace Access without perf)
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi everyone,
Does anyone know how to figure out this problem? I appreciate if anyone could give me any suggestions or ideas.
Jiawen
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
What's your CPU model?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Carlos,
The CPU is Eighteen-Core/36-Threads Intel® Xeon® E5-2699 v3 2.3GHz-45MB Shared L3 Cache-9.6GT/s QPI-145W-22nm. Does it support the rapl architecture?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Carlos,
When I compile the code, I still get the error message as below:
[liu@fornax ~]$ gcc rapl-read.c
/tmp/ccKurDYv.o: In function `rapl_msr':
rapl-read.c:(.text+0x3f6): undefined reference to `pow'
rapl-read.c:(.text+0x43b): undefined reference to `pow'
rapl-read.c:(.text+0x480): undefined reference to `pow'
collect2: error: ld returned 1 exit status
Do you know what is the reason?
Jiawen
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hey,
you need to compile with the flag -lm
regards
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Carlos,
After I run it, I got the following info showing that No perf_event rapl support found. I still didn't get the power consumption of CPUs. Do you know what's the problem?
[liu@fornax ~]$ sudo ./a.out
No perf_event rapl support found (requires Linux 3.14)
Falling back to raw msr support
Found Haswell-EP CPU
Checking core #0
Power units = 0.125W
CPU Energy units = 0.00006104J
DRAM Energy units = 0.00001526J
Time units = 0.00097656s
Package thermal spec: 145.000W
Package minimum power: 69.000W
Package maximum power: 290.000W
Package maximum time window: 0.045898s
Package power limits are unlocked
Package power limit #1: 145.000W for 0.009766s (enabled, clamped)
Package power limit #2: 174.000W for 0.002930s (enabled, clamped)
Package energy before: 75131.813354J
PowerPlane0 (core) for core 0 energy before: 0.000000J
rdmsr:pread: Input/output error
Jiawen
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Jiawen,
https://software.intel.com/pt-br/forums/software-tuning-performance-optimization-platform-monitoring/topic/557622
Check that topic best reply from Patrick. Maybe you have a similar problem so, there are some MSR's that are not compatible with your processor, maybe they are the same since it is a E5 too.
Check if it will help you!
Try it and give some feedback :)
Regards!
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi all,
I'm having the same problem. The CPU is Xeon(R) CPU E5-2680 v3. Isn't there a way to make it work?
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
