QPI is either 0 or not a number
pbkenned1
I am trying to measure QPI bandwidth on a dual socket Sandy Bridge E5-2670 SGI machine.  Do the QPI counters work in PCM V2.3?
I use pcm.x to monitor the QPI output.
Here is the output sample, and you can see that QPI is either 0 or not a number.
Intel(r) QPI data traffic estimation in bytes (data traffic coming to CPU/socket through QPI links):
               QPI0     QPI1    |  QPI0   QPI1
SKT    0        0        0     |  -2147483648%   -2147483648%
SKT    1        0        0     |  -2147483648%   -2147483648%
Total QPI incoming data traffic:    0       QPI data traffic/Memory controller traffic: -nan
Intel(r) QPI traffic estimation in bytes (data and non-data traffic outgoing from CPU/socket through QPI links):
SKT    0     9223372 T   9223372 T   |  -2147483648%   -2147483648%
SKT    1     9223372 T   9223372 T   |  -2147483648%   -2147483648%
Total QPI outgoing data and non-data traffic:    0
SKT    0 package consumed 46.27 Joules
SKT    1 package consumed 44.40 Joules
 TOTAL:                    90.72 Joules
SKT    0 DIMMs consumed 6.45 Joules
SKT    1 DIMMs consumed 6.03 Joules
 TOTAL:                  12.48 Joules
The pcm version is:
Intel(r) Performance Counter Monitor V2.3
Roman_D_Intel
Hi Patrick, QPI metrics in PCM might not work on Sandy Bridge E5-2670 if more than 1 instance of PCM is running. Please try to run just single instance. The number of instances (if > 1) is output on PCM start up. Best, Roman
pbkenned1
It seems PCM starts two instances by default. How do you run just one instance? I couldn't find any documentation describing how. Thanks, Patrick
Roman_D_Intel
PCM always starts single instance. It could be that the other instance was killed/died unexpectedly not cleaning up the system instance counter properly. Stop all PCM instances and execute "rm -rf /dev/shm/sem.*Intel*PCM*" to clean up the instance counter. Hope it helps, Roman
zhanhong_z_
Hope it helps,
Roman
Hi Roman, I did the following command and restart pcm tool rm –rf /dev/shm/sem.*Intel*PCM* but i got some error: ERROR: QPI LL counter programming seems not to work. Q_P0_PCI_PMON_BOX_CTL=0xffffffff Please see BIOS options to enable the export of performance monitoring devices. ERROR: QPI LL counter programming seems not to work. Q_P1_PCI_PMON_BOX_CTL=0xffffffff Please see BIOS options to enable the export of performance monitoring devices. ERROR: QPI LL counter programming seems not to work. Q_P0_PCI_PMON_BOX_CTL=0xffffffff Please see BIOS options to enable the export of performance monitoring devices. ERROR: QPI LL counter programming seems not to work. Q_P1_PCI_PMON_BOX_CTL=0xffffffff Please see BIOS options to enable the export of performance monitoring devices. Max QPI link speed: 16.0 GBytes/second (8.0 GT/second) I couldn't find any option to export the performance monitor, the mother board is Intel® Server Board S2600JF. Is it possible to enable it? Thanks, zhao
