Question about Intel Performance Counter Monitor
the_beginner
Hello!
Can you advice me, please, where can i find some log files after i run pcm.exe ?
Thomas_W_Intel
I usually just redirect the output to a file, i.e.
pcm.exe > pcm.log
On Linux, it is also very simple to print the output at the same time with
pcm.exe | tee pcm.log
Alternatively, you can use the fairly recent file output
pcm.exe -csv=pcm.csv
Kind regards
Thomas
Roman_D_Intel
pcm.exe does not log anything by default. What are you looking for?
Roman
Thomas_W_Intel
pcm.exe > pcm.log
Kind regards
Thomas
the_beginner
Thank so much!
I am looking for how to execute L2 hit/miss and L3 hit/miss. Because of that i've got some questions:
1. Why there is written "L2MISS: L2 cache misses (including other core's L2 cache *hits*)" ? How can i get L2 cahce misses without other core's L2 cache hits?
2. I run pcm.exe on Ubuntu so.. when i write "./pcm.x" i can see the work of all cores but i can't see the parameters for "READ", "WRITE" and "I/O"? And when i use "./pcm.x 1 -ns -nc" I can see "READ", "WRITE", "I/O" but without separation into cores ( only TOTAL data).
Can you advise me how can i fix it?
Thomas_W_Intel
1. If the L2 cache is missed on core A, the cache line might reside in some other core. We therefore consider this a miss since the core that requests this cache line does not find it in its own L2 cache.
2. PCM monitors READ and WRITE traffic directly in the memory controller. The monitor therefore does not distinguish between traffic of individual cores but only per memory controller.
the_beginner
Also i didn't get why when i run pcm.exe in Ubuntu terminal i can see the measurements of L3Miss and L2Miss in K and L3Hit and L2Hit in percentages but when i redirect the output to a file i can't understand the dimension of my measurements. (is it still in K for L2Miss and L3Miss, is it still in GBytes for Read and Write)?
Just in case, the output file and screen shot are in attachments.
440243
Screenshot from 2014-11-17 19:36:13_0.png
Thomas_W_Intel
When writing to a csv file, values are converted to a standard unit. In normal output, the format varies between K, M, and G, depending on the size. The idea is that the csv output should be simple for automatic processing. The screen output should be simple for human readers.
I'm sorry if this confused you.
In case of cache misses, the csv file prints millions of misses.
You can find a full list of descriptions for the columns in the csv file in this blog.
