Sandy Bridge i5-2500k uncore ARB events
Ying_Y_
Hi All,
I read Intel SDM and found out two uncore events: UNC_ARB_TRK_REQUEST.ALL and UNC_ARB_TRK_OCCUPANCY.ALL. From my understanding, ARB occupancy refers to memory requests waiting to be serviced by iMC. So average memory request latency can be calculated as  UNC_ARB_TRK_OCCUPANCY.ALL / UNC_ARB_TRK_REQUEST.ALL. Is that correct?
I tried to monitor the memory request latency by setting up MSRs in the following way:
/* enable uncore monitor */
wrmsr(MSR_UNC_PERF_GLOBAL_CTRL, 0x20000000);
int i;
/* need to lock bus to initialize occupancy */
asm volatile ("xchgl %0, %%eax"::"m" (i):"eax");
wrmsr(MSR_UNC_ARB_PERFEVTSEL0, 0x80 | (0x01 << 8) | (0x01 << 22));
wrmsr(MSR_UNC_ARB_PERFEVTSEL1, 0x81 | (0x01 << 8) | (0x01 << 22));
Periodically I checked the latency value by doing:
arb_occupancy = rdmsr(MSR_UNC_ARB_PER_CTR0);
arb_request = rdmsr(MSR_UNC_ARB_PER_CTR1);
latency = arb_occupancy / arb_request;
I ran two benchmarks A and B. A is sequential memory access (int array[...], size much larger than L3 cache, 32 bit program):
while (1) {
  for (i = 0; i < SIZE; i ++) {
    tmp += i;
    array += i;
    tmp = (tmp + 1) % 1030;
B is pseudo random memory access:
while (1) {
  for (k = 0; k < 1030; k++) {
    j = 0;
    for (i = k; i < SIZE; i += 1030) {
      index = i + j;
      array[index] += index;
      j = (j + 1) % 1030;
I ran A or B in the idle system separately and monitored their latencies. I would expect sequential one has smaller latency than random one. But they were the same.
So did I misunderstand those ARB events? Or set those MSRs in the wrong way? Or issue with my benchmarks? Any thought would be much appreciated! Thanks!
A_T_Intel
Hi Ying Y.
The formula you have for the average memory request latency looks correct to me (UNC_ARB_TRK_OCCUPANCY.ALL / UNC_ARB_TRK_REQUESTS.ALL).  This will give you the latency in terms of core clocks.
Are you getting reasonable values for UNC_ARB_TRK_REQUESTS.ALL for both cases?
If so, my first thought is that the hardware prefetchers are adequately prefetching both cases. I would first try to disable the hardware prefetchers.
If not, then I'd look at the assembly and make sure the compiler is doing what you expect with your code.
Ying_Y_
Perry Taylor (Intel) wrote:
Hi Ying Y.
Thanks Perry! I think I figured out! The problem is, for the pseudo random access, adjacent accesses go to different memory banks, leading to better bank level parallelism.
A_T_Intel
Glad to hear it!
