Some problems about /sys/devices/uncore files
Duan_Z_
I had some problems when I was using pmu-tool (https://github.com/andikleen/pmu-tools) on different kernel versions. The pmu-tool dosen't work well and I found the pmu-tool error happens when my /sys/devices/ directory doesn't contain any uncore_* files.
So how can I install/add these files? Is there away to measure the QPI load without these devices? Or can I use PMU-TOOL well with out this uncore_* files?
Duan_Z_
Is there something wrong in my linux kernel configuration ?
Duan_Z_
When I use lspci | grep Performance
7f:08.2 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 QPI Link 0 (rev 04)
7f:09.2 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 QPI Link 1 (rev 04)
7f:0b.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring (rev 04)
7f:0b.5 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 2 Monitoring (rev 04)
7f:0b.6 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 2 Monitoring (rev 04)
7f:10.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface (rev 04)
7f:12.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 (rev 04)
7f:12.5 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 1 (rev 04)
ff:08.2 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 QPI Link 0 (rev 04)
ff:09.2 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 QPI Link 1 (rev 04)
ff:0b.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring (rev 04)
ff:0b.5 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 2 Monitoring (rev 04)
ff:0b.6 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 2 Monitoring (rev 04)
ff:10.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface (rev 04)
ff:12.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 (rev 04)
ff:12.5 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 1 (rev 04)
The Performance counters are available but there are nothing in my /sys/devices
[liao@node1-centos7 devices]$ ls -d /sys/devices/uncore_*
ls: cannot access /sys/devices/uncore_*: No such file or directory
Dmitry_R_Intel1
What OS and what kernel version you have? One possibility is that OS kernel is too old and doesn't have support for uncore performance monitoring for your CPU.
Duan_Z_
OS is the Centos 7 and the kernel version is 3.11.0 and 3.10.0-123.el7 (both wrong).
I can get the PMU counters information in  lspci | grep Performance. So I think maybe the BIOS is right.
Duan_Z_
Accurately, it should be the kernel of the Intel-PMFS (https://github.com/linux-pmfs/pmfs), which is based on Linux kernel 3.11.0.
Dmitry_R_Intel1
From the pmu-tools readme:
"For Haswell EP support a 3.16+ kernel with the patches in patches-3.16 applied are needed. Future kernels should also support this by default."
So looks like you need to upgrade.
Duan_Z_
But I can run on kernel 3.10.0-327.36.3.el7.x86_64, so is it a coincidence or am I very lucky?
I didn't find linux/tools/perf/pmu-events/ in linux3.11.0, was it caused by this? Is this a simple question that the kernel does not support?
Duan_Z_
But I compared kernel 3.10.0-327.36.3.el7.x86_64. I didn't find anything different from 3.11.0. So, if I change to 3.16+, can I really solve this problem?
McCalpinJohn
If I understand the naming conventions correctly, kernel 3.10.0-327.* is a Centos 7.2 or RHEL 7.2 kernel that has many back-ported features from later kernels.  We recently upgraded most of our systems from CentOS 7.2 to 7.3 (kernel 3.10.0-514.*), but a quick check on a box that is still running CentOS 7.2 shows basic Haswell performance counter support (including uncore devices) in /sys/bus/event_source/devices/.   Only a few of the uncore devices have event names defined, but events can often be encoded in raw format provided that the OS supports the interface to the relevant uncore box.
