Using PCM to monitor specific portions of code
Stanley_Y_
Hi!
So I'm trying to work with the Intel Performance Counter Monitor and monitor a specific section of my code.
I've tried following this guide listed here - https://docs.it4i.cz/anselm-cluster-documentation/software/debuggers/intel-performance-counter-monitor
However, after running the command to compile, I'm getting a ton of errors from files included in the cpucounters.h file (msr.h, width_extender.h, as well as the actual cpucounters.h file. I'm using the default cpucounters.h file included in PCM "V2.11.1 (2016-10-21 16:06:24 +0200 ID=6cc1299)"
Here's an example of some of the errors.
cpucounters.h: At global scope:
cpucounters.h:91:17: error: ‘shared_ptr’ is not a member of ‘std’
     std::vector<std::shared_ptr<PciHandleM> > imcHandles;
cpucounters.h:91:43: error: template argument 1 is invalid
cpucounters.h:91:43: error: template argument 2 is invalid
cpucounters.h:91:45: error: expected unqualified-id before ‘>’ token
cpucounters.h:92:17: error: ‘shared_ptr’ is not a member of ‘std’
     std::vector<std::shared_ptr<PciHandleM> > qpiLLHandles;
cpucounters.h:92:43: error: template argument 1 is invalid
Any thoughts?
Thomas_G_4
New Contributor II
The std::shared_ptr construct is a C++11 feature. Maybe you have to activate C++11 for your compiler or you need a later version of your compiler if it does not support C++11 at all.
