pushq cost too many cpu times
raidencheng
hi all
when we use vtune to collect light-weight hotspots, we found this
Address Line Assembly CPU Time Instructions Retired
0xdd6d70 499 pushq %rbp 0.573s 1,184,000,000
how can a pushq cost such many cpu times? this make a function cpi = 2, and we want to fix it, but dont know how.
any suggestion is appretiate. Thanks.
Hussam_Mousa__Intel_
New Contributor II
In hotspot analysis, the instruction identified is the active Instruction Pointer value when the event counter overflew (in this case INSTR_RETIRED).
Typically, this points to the application function which was statistically responsible for generating lots of this event/time spent.
Typically, the latency inducing instructions are occuring prior to the identified event. if this event is in a loop with some loads for example, these maybe high latency loads.
Hope this helps,
Hussam
Note: there's a forum dedicated for Vtune Amplifier analysis and issues.
