whea uncorrectable error
Mrcrypto
hey guys i really need some help as i cant pin point the problem,
i keep getting the blue screen of death after a few minutes once i log into windows, the whea uncorrectable error.
ive tested my cpu and memory both seem to be fine, ive installed windows again and still my pc freezes and gives me the blue screen.
i then took out my gpu and used the onboard graphics, booted up fine and once again blue screen, this is really starting to get to me now as i dont want to spend money on parts that may or may not be broken,
can someone help me please? thank you
Graham897Williams
Hello!
The WHEA_UNCORRECTABLE_ERROR usually points to hardware or low‑level driver issues. Since reinstalling Windows and removing the GPU didn’t help, the likely causes are motherboard, PSU, or storage problems, or outdated BIOS/drivers. Check temps and voltages, update BIOS and chipset drivers, run storage diagnostics, and test with minimal hardware. If the error persists, unstable power or a failing motherboard are the most probable culprits.
AlHill
@Graham897Williams   ChatGpt answers are so lame....
[CoPilot is a virus]
Mrcrypto
Thank you for the reply,
So there’s no way to single out the cause of my problem? I have to check everything individually? Brilliant lol
