Thunderbolt™ Share
Support for issues related to Thunderbolt™ Share
59 Discussions
Lunar lake PCIE Crash while connecting EGPU
Alfred_Yuu
BSOD with stopcode (WHEA_UNCORRECTABLE_ERROR) pops out after receiving hundreds of corrected errors on pci express legacy endpoint.
This happens while running programs on egpu. I am currently using Dell's XPS 13 with Ultra 7 258V processor, linking my Rtx 4060 through Intel's JHL7540 Thunderbolt Controller.
I have installed every single driver available on Dell's official website and from windows updates. I am sure the problem is probably on the new laptop because I purchased a brand new thunderbolt cable and Razer core x chroma to prove my theory, and both the docking station and cable work on my previous xps 13 (1185g7). Will it be possible that intel releases patches on the cpu's thunderbolt controller?
Here is the error message i got from event viewer:
A corrected hardware error has occurred.
Component: PCI Express Downstream Switch Port
Error Source: Advanced Error Reporting (PCI Express)
Primary Bus:Device:Function: 0x2:0x1:0x0
Secondary Bus:Device:Function: 0x0:0x0:0x0
Primary Device Name:PCI\VEN_8086&DEV_15EF&SUBSYS_00008086&REV_06
Secondary Device Name:
Component: PCI Express Legacy Endpoint
Primary Bus:Device:Function: 0x3:0x0:0x0
Primary Device Name:PCI\VEN_10DE&DEV_2882&SUBSYS_27AA107D&REV_A1
Labels (4)
DhannielM_Intel
Hello Alfred_Yuu,
Thank you for posting in the community. To further investigate, I have a few questions I'd like to ask. Please see them below:
  1. Is there a lightning symbol near the Type C port on your laptop?
  2. Have you contacted Dell to verify if your laptop is Thunderbolt 4 certified?
  3. Are there any yellow warning signs in the Device Manager?
  4. Have you reached out to Dell for further assistance?
Additionally, I want to set the right expectations regarding this matter. Since you're using an Original Equipment Manufacturer (OEM) device, I can only provide general troubleshooting. If the issue persists after these steps, I recommend contacting Dell for further investigation.
To gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here: Help Guide for the Intel® System Support Utility
Dhanniel M.
Alfred_Yuu
Thank you for the reply.
Before uploading my laptop's info, i can first answer the question you raised.
1: Yes. Dell's XPS 13 series laptop usually equip with thunderbolt port only. In my case, both port on the left and right side are thunderbolt 4 compatible. There is no more physical ports on my laptop other than the two. (I also tried using both sides if you wonder)
2: Yes, or else my laptop would not be able to connect to my egpu at the first place.
3: No. When the egpu is connected but not in use, everything seems normal, even the thunderbolt controller at U.S.B. controller shows working properly.
4: Yes, actually, but they dont seem to be able offering any kind of professional help. Not even with reflecting issues and rolling patches on this matter. I have nowhere to ask for assistance but here.
You can find the SSU file of my laptop's info below. You may also want to take a look at the corrected errors I encountered before the crash. You can find it in my previous comment. My laptop also created tons of dump files while suffering from BSODs. I just don't know how to extract the files. Please guide me if further information is needed.
Alfred_Yuu
Besides, isnt lunar lake's thunderbolt controller integrated into the die's platform controller tile? (the one near filler tile) Strangely I have never received any updates or patches on the thunderbolt controller from both dell's official website and intel's page.
DhannielM_Intel
Hi Alfred_Yuu,
Could you please confirm whether you have the latest Thunderbolt driver and firmware from Dell? Have you tried using an older Thunderbolt driver for testing purposes? Additionally, could you check if there is a BIOS update available for your laptop? If an update is available, please consider installing it, as certain BIOS settings can impact eGPU functionality. Also, ensure that Thunderbolt Boot Support is enabled in your BIOS settings.
For extracting Event Viewer log files, please follow the steps outlined below:
  1. Please provide an application event viewer log from your system. Below are the steps to generate the logs
    1. Right Click on the Start Button
    2. Click on Event Viewer
    3. Click on the chevron of the Windows Logs
    4. Right Click on the Application and select Save All Events As
    5. Save the file and send us a copy
    6. make sure to indicate the timestamp of the crash
  2. Please provide an System event viewer log from your system. Below are the steps to generate the logs
    4. Right Click on the System and select Save All Events As
Dhanniel M.
DhannielM_Intel
Hi Alfred_Yuu,
I wanted to check if you've seen my suggestion and request for the Event Viewer logs. I've provided the steps on how to obtain them. Please share the logs with me at your earliest convenience.
Dhanniel M.
Alfred_Yuu
Sorry to keep you waiting. Tomorrow is my country's public holiday. I will gather the data in the next two days.
DhannielM_Intel
Hi Alfred_Yuu,
Sure no worries, I will be waiting for those information thank you.
Dhanniel M.
RobbieR_Intel
Hello Alfred_Yuu,
I wanted to check in and see if you would be able to provide the information being requested. Whenever it’s convenient for you, just let me know; I'm happy to continue assisting you.
Robbie R.
Alfred_Yuu
Regarding the questions you raised, I have double-checked and confirmed that both the thunderbolt driver and firmware are up-to-date. I have also managed to find older version from the official website. Sadly that didnt do any help. As for the bios update, I usually check for any updates every week, hoping that one of the updates will solve the issue. Thunderbolt boot support is being enabled by default.
Please check the link below. This website doesn't allow uploading MTA and evtx. The crash(BSOD) happened at 15:13. Right after running a game for less than a minute.
https://drive.google.com/drive/folders/1Bxs7eHJJpyelp19COtzc7JQrdJjUYg3O?usp=drive_link
DhannielM_Intel
Hello Alfred_Yuu,
Thank you for providing the Event Viewer logs. I will conduct a thorough investigation and update you as soon as possible.
Dhanniel M.
DhannielM_Intel
Hello Alfred_Yuu,
I was able to further check this internally, and based on my findings. Intel does not recommend using any kind of adapters and can not guarantee 3rd party products/adapters will work as expected as indicated on our public article: Using Video Cable Adapters, Splitters and/or Docking Stations in Computers not Manufactured by Intel.
At most I can only suggest the following to troubleshoot the issue(s):
  • Use a direct connection with a single cable that has the same connection type on both ends (HDMI to HDMI, DP to DP, etc.).
  • Check the display cable to ensure the cable is good and that it isn't the source of the display problem.
  • Update the graphics driver to the latest version. Contact your system manufacturer to check if there is a graphics driver update available for your system.
  • Check if Windows* and your BIOS is up to date. Check with the system manufacturer to see if updates are available for your system.
  • Install the latest generic graphics driver released by your GPU manufacturer
  • If using a docking station, update the dock driver to the latest version. Contact your system manufacturer to check if there is a driver update available for the dock.
Furthermore, for future questions and inquiries related to the Thunderbolt product, please contact the manufacturer directly for sales and support. Their teams are trained and best to troubleshoot any issues. As this is also indicated on the Thunderbolt Technology support website as well.
As I mentioned earlier, since this is an OEM device, I can only offer general troubleshooting guidance. Our investigation indicates that intervention from your system manufacturer is necessary, so please reach out to them for further assistance. Consequently, I will be closing this inquiry. If you require additional help, please feel free to submit a new question, as this thread will no longer be monitored. Thank you for your understanding.
Dhanniel M.
Lyle_Warnke_Intel
You may wish to retest after installing the latest Windows 11 update released at the end of July.
Yan7
Hello, unfortunately, the latest update did not help, I still have the exact same problem on my Lenovo ThinkPad T14 Gen 6 with Intel® Core™ Ultra 5 Prozessor 228V.
