Wireless
8721 Discussions
版本23.10.0.8的无线网卡驱动时,logi的flow功能不能正常使用,回退上个版本才行
lzq1996
网卡AX211和AX201都有这个问题
Jose_Intel
Hello @lzq1996
Thank you for posting on the Intel️® communities.
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Please confirm if the translation is accurate: “If the wireless NIC of version 23.10.0.8 is used, the flow function of logi cannot be used normally, so you have to roll back to the previous version. Both the AX211 and AX201 network cards have this problem”
We sincerely regret you are having issues with the Intel wireless adapters, we will be more than happy to assist you.
Please answer the following:
·      Was it working before?
·      Is this issue happening at home, office environment or both?
·      Have you checked if this issue happens on different networks?
·      Have you modified any WiFi adapter settings before issue appears?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
Jose_Intel
Hello lzq1996
We hope you are doing fine.
Were you able to check the previous questions?
Let us know if you still need assistance by attaching the required report.
Jose B.
Jose_Intel
Hello lzq1996
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
