Wireless
8696 Discussions
22.220.0.4 driver
ZibiHUN
Hi!
If I install the 22.220.0.4 wifi driver with Intel Driver & Support Assistant, my computer is not able to access the internet (Windows 11 says: No internet, secured). If I remove it, the default Microsoft driver or the latest manufacturer driver works well.
I have tried to reinstall Windows 11, but nothing changed.
Hardware: MSI H510M PRO with Intel® Wi-Fi 6E AX210 160MHz.
Thanks in advance!
ZibiHUN
DeividA_Intel
Hello ZibiHUN,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6E AX210.
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Bluetooth working?
3. Is the issue present when you install it manually?
4. What is your BIOS version?
5. Do you see an error in the device manager when driver 22.220.0.4 is installed?
Deivid A.
DeividA_Intel
Hello ZibiHUN,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello ZibiHUN,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
